Re:Weird grind\rattle taking off in 1st gear 2019 Jimny
19 Nov 2019 12:44 #215769 by Shiftingsideways
I have just had mine in for the 2 month check along with fitting a rear camera and mudflaps and I asked them to investigate the noise as I have had it since day 1.
They have just called to say that they have confirmed the noise is in line with the bulletin, Q-A6G-004, and will seek approval from Suzuki GB before ordering the parts for fitment.
Andrew
  • Bruce
19 Nov 2019 12:49 #215770 by Bruce
Q-A6G-004 is what I have been fited from dealer but the noise is still there for some reason.
19 Nov 2019 18:00 #215780 by Bob1050
So in a nutshell - exactly what problem is this addressing? Is it sloppy clearances, manufacturing, design or assembly issue? Should I worry? Am I facing a minor irritating noise or am I likely to suffer catastrophic failure at 58.7 mph in 5th gear?
  • Turr1can3
19 Nov 2019 21:06 #215784 by Turr1can3
I wouldnt be that concerned its something to do with slack in some chain in the xfer box when taking off from first at 2k rpm or more.
I have spoken to another owner.. who is a mechanic and he has the same issue.
He is not overly worried but is aware of it.
Also Bruce .. i wonder if they even did the job..
Its a bit of a worry that the noise is still there.
Anyway early days yet the issue does seem to be wide spread and common.
  • Bruce
29 Nov 2019 06:20 #216056 by Bruce
Dealer have tested pretty much everything on my Jimny this week, I'm a little bit concerned about that noise still there even have the transfer case revised kit installed, they changed both transfer case and gear box oil and today I'm taking it to do some offroad, it stay in 4H for around 3hours 4L for around 2hours, drive it back around city straight after that, guess what I found? The noise is unnoticeable, only does it on some really steep hill and the dB is lots smaller than before, so from this point it seems like the more you do offroading the left chance it makes noise......
  • Turr1can3
02 Dec 2019 23:50 #216165 by Turr1can3
Yeah
I found if you just put it into 4h then back into 2wd it seems to go away for a while...
Strange..
Time to create page: 0.242 seconds
