G13bb engine queries
- mickt
11 Feb 2015 19:39 #137622
by mickt
Replied by mickt on topic G13bb engine queries
In to taking the gearbox out now whilst I have the engine out. And guess what, the rear engine mounting/gearbox mounting is kaput! So where is the place to get this? Also the plate covering the flywheel at the bottom of the engine that the DVD calls the "clutch housing lower plate" has/had a felt type seal fitted to the upper edge. It was soaked in oil and muck and fell off. Does/has anybody found an replacement seal? It seems to be self adhesive.
11 Feb 2015 19:56 #137623
by j999pre
Grey pick up Jimny
Replied by j999pre on topic G13bb engine queries
Martin on here for the rear engine mount as its known
Draught excludeder should work fine
Grey pick up Jimny
The following user(s) said Thank You: mickt
- mickt
11 Feb 2015 20:05 - 12 Feb 2015 11:06 #137627
by mickt
I found this on ebay item no. 111559629151 Looks the right one but it is from Estonia. I have had some bits from the EU and found them very good and helpful. Is it a good price? I have just checked the dealer price and they want £25.54 +VAT. I also need the fibre seal that goes between the front and mid exhaust pipes. Any ideas from where I can get that. The dealer wants £13.59 +VAT?
Last edit: 12 Feb 2015 11:06 by mickt. Reason: Added further info.
- mickt
13 Feb 2015 20:36 #137841
by mickt
I decided to bite the bullet and order a rear mounting on line. The item I had highlighted had ended so I did a search using the part number710-76J00 which xrefers to SZM-SN413RR and found a website
www.febest.eu
which has a good selection of parts for the Jimny as well as lots of other cars. Free delivery as well and only £10.59. it is well worth a view.
- troggy
15 Feb 2015 08:55 #137987
by troggy
Replied by troggy on topic G13bb engine queries
It's very handy that you are doing this at the same time as me! I also puzzled over the bottom pulley but found it in the service manual (from rhinoman) about the bolts. Guess getting those off is my next job.
- mickt
15 Feb 2015 19:53 #138025
by mickt
I took the bolts off first and could not move it so I took the centre bolt out and still had a job shifting it. Corrosion was the problem and it had filled in the gap between both the pulley and the bolt/washer so they looked like a single unit. Not wanting to use too much leverage it was the easy route to removing the pulley without damaging anything. I thought it strange to have the bolts and not being able to remove it separately hence my caution.
Time to create page: 0.103 seconds
