G13bb engine queries
- troggy
18 Feb 2015 17:46 #138321
by troggy
Replied by troggy on topic G13bb engine queries
Luckily I had a puller which did the job!
I've almost got mine back together, after a few false starts.
I'm sliding down a steep learning curve!
good luck
good luck
- mickt
18 Feb 2015 19:55 #138353
by mickt
Replied by mickt on topic G13bb engine queries
Just thought I would pass on a parts supplier some might find useful. Having took the exhaust front pipe off during the engine and gearbox removal I found I needed one of the conical gaskets that go between the pipes. I also decided to replace the two mounting rubbers I removed also. These can be expensive from the dealers. The gasket from them is priced at £13.59+VAT!. I found a supplier on the net @www.exhaustpartsuk.com. They are called Myriad Automotive. They are in Walsall and their Tel.No. is:- 0191500256 The two rubbers and the gasket worked out at £13.85 delivered!
- mickt
19 Feb 2015 20:24 #138518
by mickt
Another problem drain plug saga reared its ugly head on the gearbox. Could not get the drain plug off as it had been thread sealed and the square plug receptacle showed signs of attempts with a 3/8 bit. This sometimes works as it is only 0.55mm smaller than the 10mm of the receptacle. In fact I managed to get the fill plug undone using one but it took two of us, one to hold the box and me turning and pushing the bar and adaptor. But the drain was a different story. Due it is an ali casing I did not want to resort to heat so I sourced a 10mm adaptor on the net. Came next day and bingo. It was tight but as it was the perfect size it worked. It was a 3/8 drive and so needed an extension bar on the turning point to get it free. I would recommend members to only use a 10mm bit or suffer the consequences. For those of you interested I paid £11.06 for the bit and postage fetched the total to £12.85. It is a good make, Britool part number E200205B and I got it from a firm called Motorsport-tools.com. Tel no. 01758357000.
- troggy
20 Feb 2015 17:00 #138596
by troggy
Top tips! I bought a set of drain plug sockets for £15 quid but no 10mm so I will invest in one also. Front and rear diff fill plugs loosened with the gear I've got, but only front drain plug. Don't want to push it with the rear drain plug and round it off so I'll get the 10mm.
- mickt
20 Feb 2015 19:14 #138604
by mickt
I have a set of the drain plugs I think you are on about. Comes in a tin box and there are 6 different double ended plugs of either square or hexagon form. Mine is a sykes pickavant but others like Draper sell them too. They generally do any job but the nearest in the kit is 11mm or 8mm. Typical of Suzuki to use a different size than normal! Instead of the usual 13 and 15 mm bolt heads that all metric cars used to be they tend to opt for the 12 and 14 mm sizes!
- troggy
20 Feb 2015 20:06 #138628
by troggy
YES, bang on! It's a Draper set and has already come in useful as the rocker shaft plug on the head took some loosening, and I managed by banging one of the draper set in. Tight fit but came undone.
Still going to get one of those 10mm though, as my car is an 02 plate and prob has never had rear diff oil changed.
Time to create page: 0.096 seconds
