G13bb engine queries
  • mickt
22 Feb 2015 12:37 - 22 Feb 2015 12:40 #138787 by mickt
Replied by mickt on topic G13bb engine queries
Looks a good set that.
Last edit: 22 Feb 2015 12:40 by mickt. Reason: Altered entry due did not read description correctly
  • mickt
24 Feb 2015 19:36 #139048 by mickt
I got around to stripping the head to get access to remove the valves today. This will enable me to replace the valve stem seals. Following the workshop DVD it said to remove the rocker shaft forward but I found the o-ring seal on the rear end of the shaft made that difficult and so removed it rearwards with no problems. Upon trying to remove the seal I found it so brittle it snapped so will have to be replaced. But before I could do that I had to remove the inlet valve rockers which are held in their socket on the rocker shaft by springs. The pictures show six of the eight had one of the legs of the spring broken. The broken pieces were still attached to the shaft though. Checked with the d(st)ealers and they want £4.95 each plus VAT x8 is expensive! Anybody know of a firm that can supply these?
I live in Stoke on Trent and wonder if anybody knows of a local firm that skims heads as mine could do with one due some of the Ali is showing signs of age.
  • markyp2000
24 Feb 2015 19:43 #139050 by markyp2000
Replied by markyp2000 on topic G13bb engine queries
Next time insert the pics as thay are bigger lol are you talking about the clips at the top of the pic or the ones at the bottom
  • troggy
24 Feb 2015 19:49 #139051 by troggy
Replied by troggy on topic G13bb engine queries
I know its obvious but remember to put the rocker shaft back in from the back, as the seal will not go through the exhaust rockers.............at least I think that's what I did.(?)
  • troggy
24 Feb 2015 19:55 #139054 by troggy
Thankfully my spring clips were pretty much ok apart from me being a bit kak handed on removing them. Let us know how much your head skim is, interested to compare what people are charging.
On rebuild watch out for the last spring (at the front) the one pushing against no 1 exhaust rocker, as I got it trapped in the hole and bent it. I snipped a bit off and I think I got away with it!
Best of luck.
  • mickt
25 Feb 2015 20:28 #139146 by mickt
I mentioned that I found that it had to come out at the back and that the seal was brittle so no worries there. I thought you were not going to bother stripping your head down for the skim> You did the hard bit, taking the valves out is easy. Just tap the spring with a socket and hammer and the collets pop out. Mind you replacing will be a fiddle but no worse than the old jag heads where I had to make up a cut out spacer tube to be able to fiddle the collets in. Its the first one that takes longer. Once you have the knack the rest should go quick!
The photos are quite clear which springs are broken. The second and third photos are close ups of the inlet rockers and springs.
