G13bb engine queries
- TheGreenPig22
25 Feb 2015 20:49 #139152
by TheGreenPig22
Replied by TheGreenPig22 on topic G13bb engine queries
Well it's no good telling me now that the valves are the easiest bit! I was getting to the limit of my learning curve as it is! Much more confident now I know timing marks etc is not magical scary stuff.
As I said, next time I will do a 'proper job' like you, though if it's on a dohc job that might be another matter entirely! :ohmy:
- TheGreenPig22
25 Feb 2015 20:51 #139153
by TheGreenPig22
If confused, the last is from troggy, it's just that my daughter greenpig is logged in.
- TheGreenPig22
25 Feb 2015 20:55 #139155
by TheGreenPig22
The spring I was on about was not the rocker spring clip, but the coil which pushes against the front exhaust rocker.
I have a feeling though that I am teaching my grandmother to suck eggs.
Best regards Gary (Troggy)
- mickt
25 Feb 2015 20:55 - 26 Feb 2015 20:09 #139156
by mickt
Replied by mickt on topic G13bb engine queries
I was a bit!!! I said it was easier or that is what I meant. Every job has its tricky bits, especially when the heads are Ali!
I now think that the oil in no 3 pot might be due to the piston rings. I did not want to touch the bottom end but it would be false economy not to check the rings. I bought a complete gasket set instead of the head gasket set so I have all the seals so its sump and piston removal next.
Last edit: 26 Feb 2015 20:09 by mickt. Reason: spelling correction to text
- mickt
26 Feb 2015 20:08 - 26 Feb 2015 20:10 #139262
by mickt
I understood which spring you meant. Looks like it is going to be a fiddly process. My fingers nowadays are like sausages when it comes to fiddly bits. Old age you know!
I have found a head skim firm called "Cylinder Head Ltd. here in Stoke on Trent in Victoria road for those who know the area. He reckons it will be £30 + VAT so that is what you paid troggy wasn't it?
Last edit: 26 Feb 2015 20:10 by mickt. Reason: spelling and additional text
- mickt
27 Feb 2015 20:09 #139371
by mickt
I dropped my head off at 10:30 this morning and after shopping I picked it up all done. £36 in total. Lovely old shed with great really old British machining tools and a operator who knew what he was doing. I then popped into the dealers only to find he had ordered the wrong springs. He had ordered the exhaust valve rocker ones on the rocker shaft. Good news was the correct ones were cheaper so hopefully I will get them Tuesday.
Time to create page: 0.098 seconds
