G13bb engine queries
  • mickt
11 Mar 2015 12:48 #140366 by mickt
Replied by mickt on topic G13bb engine queries
I decided to check the diff oil in the front diff. The level plug was well chewed and so I had a chance to use my new 10mm square drive sockets mentioned earlier in this thread. The one out of the kit would not move it because of the damage but the Britool one did the job no bother. The level was very high equating to 1.9Litre and according to the manual should have been only 1.35Litre. The drain plug unscrewed as you would expect with no dramas. So if you need a 10mm drain plug I recommend the Britool one! I am going to be replacing the rear axle and so will be attempting to remove the plugs from it and they look damaged. Deep joys of the Jimny world!
  • mickt
11 Mar 2015 20:16 #140398 by mickt
I attacked the rear diff today and joy of joys the drain plug was undamaged and came out sweet. Only 1.1litres in there though but nice and clean ,unlike the front which was like mud so it had water in there. The back should have had 1.5 litres. The fill plug was a bit more of a challenge. It was damaged and rusty and was a bugger to get the drive in but I managed and with a large tube got it to move with a bang. Instead of a copper washer they had used a plastic one which is what I reckon caused it to be so tight. Happy days!
  • mickt
13 Mar 2015 20:00 #140547 by mickt
Got around to pulling the three other pistons to check the rings and bores. All good though these three had carbon build up too below the oil control rings blocking the hokes. Cleaned them up and refitted OK. The big end shells show were in great condition so onto the front seal behind the lower belt pulley tomorrow.
  • mickt
14 Mar 2015 15:59 #140584 by mickt
Took the crankshaft front cover off primarily to replace the crankshaft centre seal. This panel is actually the oil pump mounting panel. I attempted to remove the Philips screws securing the pump back plate to the panel just to give the rotors a looksee to ensure all was well. Could I shift the screws? Could I hell as like. Correct size bit and even tried a impact hammer to no avail. Best left alone I think as the big end shells are in good nick. Anyway, the gasket between the block and the panel was in bits on removal. Paper or such and brittle as hell. I have bought a complete engine overall gasket kit for the G13bb engine. It was marked for a Baleno but the head gasket and valve seals are ok but it has a sump gasket which the Jimny does not use and more importantly to this thread the gasket for this oil pump panel is steel! Anybody come across this before and can it be used on the Jimny? It is the correct shape and all but I wonder do I need a dab of sealant if I use it or will it seal as is.
Time to create page: 0.090 seconds
