G13bb engine queries
- troggy
28 Feb 2015 19:00 #139459
by troggy
Replied by troggy on topic G13bb engine queries
Hey sorry I did not mean to put it quite the way it came across.
Yes, 35 for cash, well happy, the guy also knew his onions.
Doing piston rings etc becomes like an engine rebuild, which I would love to tackle one day, when I am feeling brave. Though I must admit that it is all becoming less of a mystery. Good job I'm practicing on a g13b.
- mickt
28 Feb 2015 20:26 #139472
by mickt
Replied by mickt on topic G13bb engine queries
It appears one of the washers that go under the valve springs was missing on head strip. Ordered one when I reordered the correct rocker springs. I whipped the oil sump off today. There was no gasket fitted. just the red silicon sealant! Well stuck was the pan but a few careful blows with the hide faced loosened it. I removed the no 3 pot piston expecting to find broken, or at least stuck, rings but apart from a very slight bit of carbon on the piston every thing looks fine. I am glad as the dealers want £40 +VAT a piston set. I will get the micrometres out tomorrow and check the wear of the bore.
- troggy
28 Feb 2015 20:29 #139473
by troggy
It's been a long time since i've got my micrometres out.
- mickt
04 Mar 2015 20:08 #139869
by mickt
Eventually got round to checking the bore size and piston size. The bores all checked out at 2.91in which is 74mm and the piston was 2.913in so standard and all rings ok and not gunged up. Onward and upward as they say.
- mickt
06 Mar 2015 19:34 #140016
by mickt
I picked up the inlet rocker springs, o ring for the rocker shaft and the missing valve spring lower washer today. £38.16!
- mickt
11 Mar 2015 12:42 #140365
by mickt
I decided to remove the oil control ring from the piston to clean it. It is in three pieces as normal, two outer split rings and a corrugated centre bit. Not too bad but found that the land they run in was carbonised and the 10 holes in the land (5 each side) was blocked with carbon. Careful cleaning with a blunt scraper and a small undersize drill cleared the holes. I wonder if that was the cause of oil getting in the exhaust port. I will now remove the other three pistons and check them too. Anybody know what the purpose of the holes are. Is it to allow the oil that the ring stop to flow back into the sump?
