G13bb engine queries
- mickt
11 years 9 months ago #137000
by mickt
G13bb engine queries was created by mickt
I decided to remove the engine as it had a history of an oil leak and the bay, engine and gearbox need a good clean and trying to do it lying on my back was not an option, especially this weather, and not all areas of the engine, bay and box are get attable with the engine in situ. Before I removed the engine, after I bought it, there was no actual running leak to see but going from past MOT advisories it was mentioned two or three times. I only drove it about 8 miles though. The owner was a bit vague saying the mechanic fixed the leak by pouring something in the engine!
I got the engine out without much issue though some of the items you have to remove, like the starter motor, must be an absolute nightmare as a stand alone removal. The access is abysmal. very long thin arms and fingers I have not got! Anyway, the first question is, are the lifting eyes fitted for head removal only or can you use them to remove the engine?
As I removed both manifolds to allow more room to remove the engine I found the number 3 exhaust port wet with oil and the plug was very oily. I suspect the valve seals are the problem and so am in the middle of removing the head. The next question here is that when lining up the cam belt at TDC with no.1 on compression to remove the belt what is the camshaft timing mark (stamped E) supposed to line up with? With the cover off there is nothing for the mark to line up with! The pulley appears to be central to the cam bearing cap but it is a bit hit and miss I reckon! The other thing I found strange was the way Suzuki fitted the bottom pulley. On most cars the crankshaft centre bolt stays put as that just keeps the drive gear in place and you can use the bolt to turn the engine when refitting the belt. The ancillary belt pulley is removed by removing the pulleys bolts. But not Suzuki. Thank god for my impact driver. It would have been a nightmare trying to stop the engine turning whilst trying to undo that bolt. There is no good place to wedge the flywheel as the flimsy plate that goes between the engine and gearbox is not up to it!
Going back to the head, I am a bit confused as the DVD repair manual I have does not mention to replace the bolts so I assume they are not stretch bolts designed to be used once AKA Fords etc. I even contacted a parts supplier who confirmed they were reusable and not listed as stretch bolts. Yet scanning the "shop" it states that they do stretch! So has anybody ever had or heard of these bolts shearing when they have been refitted? It happened to me once a few years ago when I had fitted a Ford Orion head with new bolts and then almost immediately realised I had forgotten something and had to remove the head. Sorted that and refitted the head and retorqued the bolts in stages as per the instructions as I did the first time only to have one snap!. I was not best pleased and it had gone below the level of the block. And they had never been through a run cycle, just on and off within 30 mins!
Anyway, just as well I removed the engine as after removing the clutch I have found the friction plate just about worn enough to be not worth refitting. Also the bell housing of the gearbox has a fair splattering of oil so the box will be out next to give that a good clean.
11 years 9 months ago #137023
by j999pre
Grey pick up Jimny
Replied by j999pre on topic G13bb engine queries
Yes you can lift on the lifting eyes
Yes you can reuse the head bolts
There is a notch on the rocker cover for the cam timing
The outer part of the crank pulley comes off with removal of the 5 8mm bolts
The inner cambelt pulley needs the 17mm bolt removed to take that off
Grey pick up Jimny
The following user(s) said Thank You: mickt
- mickt
11 years 9 months ago #137044
by mickt
Replied by mickt on topic G13bb engine queries
Thanks James for your replies. Having relooked at the ancillary belt pulley it does come off separately. I think that there was so much rust and muck even after cleaning that I could not see the definition between where it ended and the pulley bolt began. Plus it was a devil to get off because of the rust. A mallet and a dollop of patience and WD40 eventually won through though as you can not use levers to move it because of the danger of breaking the plastic. Of course as I was stripping the head to remove it from the block the cam cover was already off, silly me. Just changing the belt normally and it would be in place. Its old age you know!
- mickt
11 years 9 months ago #137094
by mickt
Another query is in the DVD it mentions to oil the head bolts when fitting. Now there is two schools of thought on this subject in that it is thought if the threads are lubricated then you get a false torque loading in respect to fitting them dry. Something to do about less friction. In the aviation industry, where I worked all my working life, the torque type (wet or dry) was quite specific and indeed critical in most cases. Now on the Jimny the hole the bolts go in is a dead end and too much oil could lead to a hydraulic lock and cracking of the block I would have thought. So which method is correct in your opinions?
11 years 9 months ago #137099
by Rhinoman
Replied by Rhinoman on topic G13bb engine queries
Use a little clean engine oil, the recommended torque figure takes that into account. You need to tighten them in two stages, to 20ft/lbs and then to 40ft/lbs.
- mickt
11 years 9 months ago #137537
by mickt
I have just received a full engine Gasket kit. For those interested I paid £70.07 delivered and it was from
www.thehappymotorist.co.uk
. They are like middlemen for spares but competitive prices. The kit is a FIA make and is on their website under the code "FS1576" Marked up as £63.12 and the rest is postage. Ideal if you are doing an overhaul of the engine. I also got one of those Exedy clutch kits from ebay for £48 delivered.
Time to create page: 0.104 seconds
