shock relocation
  • jonesyba420
06 Jun 2013 21:07 #73005 by jonesyba420
Replied by jonesyba420 on topic shock relocation
i cant see the front shock extenders on there? does anyone sell a complete kit of everything you need?
  • reaper
06 Jun 2013 21:14 #73007 by reaper
Replied by reaper on topic shock relocation
Think i have a set of rear locators and try mods4vits for the fronts ( not bits4vits its a different place)
  • jonesyba420
06 Jun 2013 21:24 #73013 by jonesyba420
just had a look on there and according to their description of the spring spacers they don't improve the articulation, so there's not much point me fitting them as im not putting bigger wheels/tires on so dont need the extra room in my arches. do the shock extenders/re locators improve articulation?
  • jonesyba420
14 Aug 2013 09:53 #79854 by jonesyba420
still havent got to the bottom of this, can you fit the rear shock relocation brackets with standard shocks and springs? do they make any difference this way? also the same for extending the front shocks?
  • GuardianAngel
19 Jan 2014 21:53 #101169 by GuardianAngel
Replied by GuardianAngel on topic shock relocation
jonesyba420 wrote: still havent got to the bottom of this, can you fit the rear shock relocation brackets with standard shocks and springs? do they make any difference this way? also the same for extending the front shocks?
This is what I would like to know. I would fit the rear ones if it meant less stress on the lower shock mounts, which I think it does, but am not 100% sure.
19 Jan 2014 22:01 - 19 Jan 2014 22:04 #101173 by Rhinoman
Replied by Rhinoman on topic shock relocation
The extra travel should mean that there is less spring force when the shock is at full extension so it should give the mount an easier time but you need to make sure that the shock won't bottom out and that the spring won't fall out.
Last edit: 19 Jan 2014 22:04 by Rhinoman.
The following user(s) said Thank You: GuardianAngel
Time to create page: 0.106 seconds
