shock relocation
- jonesyba420
20 Jan 2014 08:24 #101217
by jonesyba420
So you lose upwards travel but gain downwards travel?
Replied by jonesyba420 on topic shock relocation
barnes wrote: Your going to lose travel on the shocks as your compressing the shock by a inch and half meaning youll bottom out on bumps
- JuanGuillie
20 Jan 2014 10:19 - 20 Jan 2014 10:24 #101234
by JuanGuillie
Replied by JuanGuillie on topic shock relocation
I have a 2" Trailmaster Stage II Sport damper and spring set.
I did put those shock relocators on and did a full flex test, to my surprise the springs came in a very "loose" position.
Tried with a short pull on them and the spring dislocated but was kept in place by the bumpstop!
So i ordered some spring clamps and feel save with this solution now.
The travel "up and down" from the dampers is OK, still have enough !
Once you did put the rear shock relocaters on, take time to make a full flex test and see how the springs are reacting, when you give them a good pull when you're axle is at it's lowest point.
Some springs (together with the dampers) will be OK, others could fall out and others dislocate without falling out.
Depends from the make of your dampers and springs, it's worth doing this, can save you a lot of money or even your life !
Just wanted to share this.
Last edit: 20 Jan 2014 10:24 by JuanGuillie.
- barnes
20 Jan 2014 14:47 #101261
by barnes
Well by fitting these without any extra spring hight youll be compressing the damper on the road by a 1"1/2 or so. So for example if the travel of the shock was 2" before it bottoms out your now at 1/2" travel
Replied by barnes on topic shock relocation
- jonesyba420
20 Jan 2014 16:33 #101276
by jonesyba420
will it actually bottom out tho or will you hit the bump stops before the shock bottoms out?
i understand your losing upwards travel of the shock but will they give "more" downwards travel as the shock is "longer" (i know the physical length of travel hasnt increased but the shock is now longer)?
is it as simple as you lose 1.5" of upwards travel but gain 1.5" of downwards articulation?
maybe someone who has a standard jimny with relocators on the back that offroads it can fill us in :whistle:
- Alliston
20 Jan 2014 17:31 #101286
by Alliston
Replied by Alliston on topic shock relocation
Welded.new brackets for rear shocks on bumpstops give them a better angle which gives more articulation fitted with focus estate spring
Sent from my C6903 using Tapatalk
- Jimny_Aus
21 Jan 2014 00:03 #101389
by Jimny_Aus
Replied by Jimny_Aus on topic shock relocation
some hardcore brackets there....
Time to create page: 0.114 seconds
