shock relocation
12 years 9 months ago - 12 years 9 months ago #101185 by robs5230
Replied by robs5230 on topic shock relocation
Rhinoman wrote: The extra travel should mean that there is less spring force when the shock is at full extension so it should give the mount an easier time but you need to make sure that the shock won't bottom out and that the spring won't fall out.
it's not really the extra travel , its the way the bottom of the shock is turned round 90 degrees that reduces the stress. look at how the bottom of the rear shock is mounted as standard. it is not at right angles to the mounting bolt. it knackers bushes and stresses the bolt and mount. the brackets stop this.
the axles will really have to articulate to dislocate a spring
standard jimny - for now
Last edit: 12 years 9 months ago by robs5230.
  • GuardianAngel
12 years 9 months ago #101187 by GuardianAngel
Replied by GuardianAngel on topic shock relocation
Thanks. So at the moment I don't have any kind of lift but I take my J off road, so can I fit the rear brackets without a lift?
I do intend on fitting spring spacers at some point to just get a small lift for slightly bigger tyres.
  • jonesyba420
12 years 9 months ago #101188 by jonesyba420
Replied by jonesyba420 on topic shock relocation
Met a fellow forum member today,doesnt live far so met for a chat. His is standard and running relocators on the rear with no reported problems. I recon they will allow the rear to flex more,might fit some at some point.
12 years 9 months ago #101194 by mysterious
Replied by mysterious on topic shock relocation
jonesyba420 wrote: still havent got to the bottom of this, can you fit the rear shock relocation brackets with standard shocks and springs? do they make any difference this way? also the same for extending the front shocks?
after what happened with me , both shock mounts on each side on the axle for the front was broken cz the standard shocks were short. so i bought 2 new nissan pathfinder (i think it's 1993 model) and insert it .it 's 2" longer. so springs can be more oppened and dont get out holders or fall out. u dont need to buy extenders
  • barnes
12 years 9 months ago #101202 by barnes
Replied by barnes on topic shock relocation
Your going to lose travel on the shocks as your compressing the shock by a inch and half meaning youll bottom out on bumps
12 years 9 months ago #101215 by robs5230
please see the following description and explanation for fitting of the relocation brackets ( from the bigjimny shop )
www.jimny.se/store/index.php?_a=product&product_id=14
cheers rob
The following user(s) said Thank You: GuardianAngel
