shock relocation
  • jonesyba420
06 Jun 2013 16:30 #72958 by jonesyba420
shock relocation was created by jonesyba420
might sound like a stupid question but do the shock relocation brackets on the rear make any difference with standard suspension?
what are the pros and cons with fitting these to a standard truck?
  • reaper
06 Jun 2013 17:08 #72962 by reaper
Replied by reaper on topic shock relocation
No cons
Pro's ( only if used offroad)
Gives an extra dimension of shock travel
Bushes last longer
Gives 1 1/2 extra movement on the shock and therefore the axle
  • jonesyba420
06 Jun 2013 17:55 #72968 by jonesyba420
Replied by jonesyba420 on topic shock relocation
do you have to use them with the spring spacers or are they still beneficial with stock springs?
06 Jun 2013 18:20 #72971 by Halford
Replied by Halford on topic shock relocation
Hi Alex
with spring spacers they're great - huge improvement on-road - makes the truck ride far softer
see mine here
  • jonesyba420
06 Jun 2013 18:55 - 06 Jun 2013 18:58 #72977 by jonesyba420
so the relocation brackets alone make a difference?does extending the front shocks have the same effect?im not that bothered about a lift as im not planning on fitting huge wheels/tires but a bit of extra articulation is always good :) where can i get a complete kit with everything (spring spacers and the relocation brackets along with the front shock extenders)? or just the front and rear shock extenders, i know martin does the rears but cant find the front ones?
Last edit: 06 Jun 2013 18:58 by jonesyba420. Reason: more info and questions.
  • dirtydogz
06 Jun 2013 20:39 #72997 by dirtydogz
Time to create page: 0.096 seconds
