shock relocation
- jonesyba420
13 years 5 months ago #72958
by jonesyba420
shock relocation was created by jonesyba420
might sound like a stupid question but do the shock relocation brackets on the rear make any difference with standard suspension?
what are the pros and cons with fitting these to a standard truck?
- reaper
13 years 5 months ago #72962
by reaper
Replied by reaper on topic shock relocation
No cons
Pro's ( only if used offroad)
Gives an extra dimension of shock travel
Bushes last longer
Gives 1 1/2 extra movement on the shock and therefore the axle
Bushes last longer
- jonesyba420
13 years 5 months ago #72968
by jonesyba420
Replied by jonesyba420 on topic shock relocation
do you have to use them with the spring spacers or are they still beneficial with stock springs?
13 years 5 months ago #72971
by Halford
Replied by Halford on topic shock relocation
Hi Alex
with spring spacers they're great - huge improvement on-road - makes the truck ride far softer
see mine here
see mine here
- jonesyba420
13 years 5 months ago - 13 years 5 months ago #72977
by jonesyba420
so the relocation brackets alone make a difference?does extending the front shocks have the same effect?im not that bothered about a lift as im not planning on fitting huge wheels/tires but a bit of extra articulation is always good
where can i get a complete kit with everything (spring spacers and the relocation brackets along with the front shock extenders)? or just the front and rear shock extenders, i know martin does the rears but cant find the front ones?
Last edit: 13 years 5 months ago by jonesyba420. Reason: more info and questions.
- dirtydogz
13 years 5 months ago #72997
by dirtydogz
Replied by dirtydogz on topic shock relocation
Time to create page: 0.122 seconds
