shock relocation
  • Alliston
12 years 9 months ago #101470 by Alliston
Replied by Alliston on topic Re:shock relocation
Gives them a better angle and I got focus estate spring which have giving me a 2'' lift so won't be using the bomb stop I put the brackets on top so I didn't have to buy new shocks they are welded fully now Il get a picture tomorrow and post it with the shock bolted on to new brackets
Sent from my C6903 using Tapatalk
12 years 9 months ago #101505 by mlines
Replied by mlines on topic Re:shock relocation
The bottom bolts on the shocks take a beating. The natural action seems to tighten the passenger side one too tight and seem to undo the driver side one. Putting the brackets in gives two joints at 90 degrees to each other to try and absorb movement without straining the bolt, although you still need some rotation motion around the bolt (do not tighten the brackets too much).
On a standard Jimny they could mean the shocks bottom out under extreme compression. However, a crucial part of any suspension system are the bump stops and they are often forgotten in any suspension lift. By extending the bump stops you can stop the shocks from bottoming and also improve articulation, this is because a bump stop encourages the opposite end of the axle to drop rather than the local side tuck up under the wheel arch.
  • TomDK
12 years 9 months ago - 12 years 9 months ago #101508 by TomDK
Replied by TomDK on topic Re:shock relocation
mlines wrote: The bottom bolts on the shocks take a beating. The natural action seems to tighten the passenger side one too tight and seem to undo the driver side one. Putting the brackets in gives two joints at 90 degrees to each other to try and absorb movement without straining the bolt, although you still need some rotation motion around the bolt (do not tighten the brackets too much).
Spot on Martin.
I find it a bit odd that none of the Jimny suspension suppliers, ORA, Jimnybits etc. Have bump stops in their webshop. Zanfi makes some, but it's just a long piece of aluminium with a bit of rubber on top.
With longer suspension travel, the ideal bump stop slows the movement down over a distance and not just with 5-10 mm of rubber. So hydraulic bump stops would be great to have on the Jimny. Sadly, there's not enough room, unless you fabricate your own spring and shocks mounts.
Which is why I have fitted these bump stops. They work very well, and allow for some travel.
I can take some pics, if anyone is interested :)
Last edit: 12 years 9 months ago by TomDK.
  • jonesyba420
12 years 9 months ago #101552 by jonesyba420
Replied by jonesyba420 on topic Re:shock relocation
so what ive gathered so far is that its pointless fitting them to a standard height jimny without extending the rear bump stops as it'll likely cause the shocks to bottom out..............is this correct?
would we just increase the length of the bump stops by the length of the relocators?
12 years 9 months ago #101557 by Busta
Replied by Busta on topic Re:shock relocation
By fitting longer bump stops surely you are just limiting wheel travel? If the tyre isn't scrubbing, why stop it from tucking up into the wheel arch? The 'lever' effect the bump stop provides will only be transferring a small amount of weight to the lower wheel compared to if the vehicle was still sat on the springs.
I'm not saying the shock brackets don't work, just that they are pointless on a vehicle with otherwise standard suspension.
12 years 9 months ago #101558 by Busta
jonesyba420 wrote: so what ive gathered so far is that its pointless fitting them to a standard height jimny without extending the rear bump stops as it'll likely cause the shocks to bottom out..............is this correct?
You could do, but in doing so you'd be limiting suspension travel, probably to the point where the standard shock position wouldn't cause any issues anyway...
