shock relocation
  • jonesyba420
12 years 9 months ago #101418 by jonesyba420
Replied by jonesyba420 on topic shock relocation
Alliston wrote: Welded new brackets for rear shocks on bumpstops give them a better angle which gives more articulation fitted with focus estate spring
surely this puts the shocks at a random angle?got any pics with the shocks mounted and are they standard length shocks?what are you using for the bump stops now youve welded brackets where they should be?
good idea gets them up out of harms way.
12 years 9 months ago - 12 years 9 months ago #101421 by robs5230
Replied by robs5230 on topic shock relocation
i had a good look at repositioning my rear shock mounts over the weekend as i had a broken lower mount on one of them ( i have repaired it now ). but, i'm going to leave as is and look at strengthening them. they are very poor as standard.
there seems to be few options for relocation above the axle ( alliston has used one ). the drivers side is tight because of the diff. i think the best option for me is to fabricate a stronger, more protected mount to fit in the original position.
standard jimny - for now
Last edit: 12 years 9 months ago by robs5230.
  • jonesyba420
12 years 9 months ago #101426 by jonesyba420
do they just break off at the weld? (it is a little tube thing welded to the bottom of the axle correct?)
12 years 9 months ago #101454 by Busta
Replied by Busta on topic shock relocation
Fitting shock extensions with no suspension lift will mean on big compressions (e.g. potholes, speed bumps etc) your shocks are likely to bottom out before the bumpstops do. This will damage the shocks and bend the brackets.
  • GuardianAngel
12 years 9 months ago #101458 by GuardianAngel
Replied by GuardianAngel on topic shock relocation
Busta wrote: Fitting shock extensions with no suspension lift will mean on big compressions (e.g. potholes, speed bumps etc) your shocks are likely to bottom out before the bumpstops do. This will damage the shocks and bend the brackets.
Thanks that's what I wanted to hear.
12 years 9 months ago #101468 by robs5230
jonesyba420 wrote: do they just break off at the weld? (it is a little tube thing welded to the bottom of the axle correct?)
its a little tube about 4 or 5mm wall thickness but suspended from the axle on a dodgy little bracket. my bracket didn't break at the weld but 1/2 way down the bracket itself . it's the bracket that needs to be stronger
