Spark plugs
  • Cremator1
30 Dec 2018 16:57 #199721 by Cremator1
Replied by Cremator1 on topic Spark plugs
Ok thank you I shall get the kit scimike posted it’s on eBay 59 pounds that one should be ok for me I think dawn x
30 Dec 2018 17:03 #199722 by jackonlyjack
Replied by jackonlyjack on topic Spark plugs
Yes that kit will work fine :)
I used the same armstrong damper with the brackets i made ;)
  • Cremator1
30 Dec 2018 17:08 #199723 by Cremator1
Thank u just ordered it now how to fit don’t tell me I got to start measuring stuff lol x
30 Dec 2018 17:21 #199724 by jackonlyjack
lol yes but it's very straight forward stuff you will need a pencil
1,stand the damper on some wood/carpet/steel toe cap boot(this is to protect the end)
push down on it till it stops draw a line
2,pull it apart as far as it goes draw a line
3,measure the distance between the 2 lines put a mark at this point
4,push damper back in till it gets to the mark draw a line
and thats it ready to bolt on :)
  • Cremator1
30 Dec 2018 17:33 - 30 Dec 2018 17:34 #199726 by Cremator1
Mmmmm sounds ok not sure about point 4 which mark do you push it back to the last mark u made
Last edit: 30 Dec 2018 17:34 by Cremator1.
30 Dec 2018 18:02 - 30 Dec 2018 18:05 #199730 by Scimike
Replied by Scimike on topic Spark plugs
I can take some photos of mine fitted in the morning as you have the same if needed, however fitting it is easy.
Bolt on the large hanger mount to the chassis, two bolts, only fits in one place.
Push the damper full in and then fully out, mark these two travel points on the damper and then find the middle between these two marks. Set the damper in the middle of the stroke, ^^^as Jack said.
Fit the (now centered) damper to the chassis mount and the other supplied mount to the steering arm and damper. Do this with the vehicle wheels pointing straight ahead.
Check that at full lock in each direction that the damper does not exceed or hit the out two outer travel points you first marked on the damper. If they dont all is good, check everything is tight and enjoy your new steering damper.
Last edit: 30 Dec 2018 18:05 by Scimike.
Time to create page: 0.218 seconds
