Spark plugs
  • Cremator1
26 Dec 2018 10:12 #199453 by Cremator1
Spark plugs was created by Cremator1
Hi all and merry Christmas just thought I would check spark plugs this mor don’t no why lol and they are Bosch ones in would there be any benefit from fitting the proper ngk ones done 15000 miles in it they look of but do notice it does not start on the button when first starting in morning. Also is there a fuel filter that should be changed many thanks dawn
26 Dec 2018 10:25 #199454 by Lambert
Replied by Lambert on topic Spark plugs
The fuel filter is integral to the pump in the tank, it's not a service item. I have the proper ngk iridium plugs in both Ermintrude and Zebedee. They are not cheap like 20 odd quid each not cheap but they last well and haven't given a single issue.
  • Cremator1
26 Dec 2018 10:42 #199455 by Cremator1
Replied by Cremator1 on topic Spark plugs
Hi lambert hope u had good Christmas ok cool I can get a set on the bay for 45 so will get a set x
26 Dec 2018 10:43 #199456 by Busta
Replied by Busta on topic Spark plugs
Slow starting is unlikely to be a plug issue. As long as they are Iridium, the Bosch plugs are absolutely fine and there is no reason to change them out before the standard service interval. If they are nickel (non-iridium) then they will also be fine but need changing more regularly.
26 Dec 2018 11:57 #199459 by Lambert
45quid sounds a bit too good to be true for 4, be sure you are getting what you need an not a knockoff.
26 Dec 2018 14:57 #199463 by Scimike
Replied by Scimike on topic Spark plugs
^^^^^^ I agree, plenty of counterfeit spark plugs out in the world, so get them from a reputable source. They even rip off the cheaper plugs.....
