Spark plugs
- Mattch5150
29 Dec 2018 16:53 #199653
by Mattch5150
Replied by Mattch5150 on topic Spark plugs
It is a worry, most come gapped at one mm. If not right car wont start or will run bad anyway
- Cremator1
29 Dec 2018 16:56 #199654
by Cremator1
Replied by Cremator1 on topic Spark plugs
Well these look bigger than a 1 mm gap
- Mattch5150
29 Dec 2018 16:57 #199655
by Mattch5150
If worried go to halfords and buy their silver spark plug gap tool. Gap sensors look like claws, it's about 5.99. Don't buy the cheap one it's only for below 1mm gaps. Has gap adjuster plates on it too
- Cremator1
29 Dec 2018 16:58 #199656
by Cremator1
I have a set of feeler gauges but not sure how to use them I did post pic of them
29 Dec 2018 17:00 #199657
by Busta
Replied by Busta on topic Spark plugs
If you don't have the ability to measure them yourself it's clearly best to leave them alone. It's not a critical tolerance; they will work just fine as they come in the box.
- Mattch5150
29 Dec 2018 17:00 #199658
by Mattch5150
You just need to ckmbine them together so they are 1mn thick. Then slide them in the gap. It should fit in without wobble, however it's not life or death, if it is slightly loose then it should be fine
Time to create page: 0.230 seconds
