Spark plugs
  • Cremator1
29 Dec 2018 17:01 - 29 Dec 2018 17:02 #199659 by Cremator1
Replied by Cremator1 on topic Spark plugs
Yes but need to learn please thank you dawn so in the pic of my feeler gauges what adds up to 1mm
Last edit: 29 Dec 2018 17:02 by Cremator1.
  • Mattch5150
29 Dec 2018 17:01 #199660 by Mattch5150
Replied by Mattch5150 on topic Spark plugs
As busta said they should be fine as long as they are the right ones for the car
  • Mattch5150
29 Dec 2018 17:04 #199661 by Mattch5150
You are doing well Dawn, I'm no master mechanic either. A small plastic ruler is about a mm thick on its edge. Try that also, but plugs should be fine as each model of car those plugs are designed for will have same or similar gaps
  • Cremator1
29 Dec 2018 17:14 #199663 by Cremator1
Hi thank you just want to learn how to use the feeler gauge I have x
29 Dec 2018 17:27 - 29 Dec 2018 17:27 #199664 by Busta
Replied by Busta on topic Spark plugs
Cremator1 wrote: Hi thank you just want to learn how to use the feeler gauge I have x
Is there not one with 1.0mm written on it? Otherwise, add together numbers that add up to 1. E.g. 0.8+0.2, 0.7+0.3, 0.53+0.47 etc. On your specific feeler gauges, use the lower 'mm' numbers. The upper number is the thickness in thousandths of an inch.
Last edit: 29 Dec 2018 17:27 by Busta.
  • Cremator1
29 Dec 2018 17:29 #199665 by Cremator1
No 1mm on it
Time to create page: 0.532 seconds
