Spark plugs
  • Cremator1
28 Dec 2018 19:27 #199582 by Cremator1
Replied by Cremator1 on topic Spark plugs
Hi ya thank u for looking that’s great I will have a go tomorrow when it says 0.039- 0.043 do you go some where in the middle lol dawn x
28 Dec 2018 20:10 #199590 by Kenny
Replied by Kenny on topic Spark plugs
Hardly a tuned engine....I'd stick with NGK or Bosch...both are excellent plugs.
28 Dec 2018 20:42 #199596 by Scimike
Replied by Scimike on topic Spark plugs
Yes in the middle will do, but dont get hung up on super accuracy. If you have a single feeler gauge blade within your set that sits between these measurements just use that. It should just slide through the gap with a little "drag", a gauge larger than the top limit should not.
You are just checking they have not been bashed in transit or manufactured wrong before you fit them.
  • Cremator1
29 Dec 2018 13:21 #199625 by Cremator1
Ok got feeler gauge it’s got loads of blades on it is 0.40 mm same as 0.040mm
29 Dec 2018 13:26 #199626 by reedx
Replied by reedx on topic Spark plugs
Cremator1 wrote: Ok got feeler gauge it’s got loads of blades on it is 0.40 mm same as 0.040mm
No, it is 10 times thicker.
Colin
29 Dec 2018 13:32 - 29 Dec 2018 13:37 #199627 by Lambert
Replied by Lambert on topic Spark plugs
No it's a factor of 10 different. With feeler gauges the idea is to stack up a selection of leaves together to get a desired dimension. E.g. the 0.4 with the 0.2 and the 0.5 together give you a total of 1.1mm which is the upper plug tolerance.
Also be aware that some guage sets are both metric and imperial on the same leaves. Metric will usually be tenths of mm 0.10 or possibly hundredths 0.001 of mm. imperial will always be in thousandth of an inch 0.0010
Last edit: 29 Dec 2018 13:37 by Lambert. Reason: Zeroes
Time to create page: 0.216 seconds
