Swift 1.6vvt engine into a 2007 vvt jimny project
  • 1066Boy
15 Feb 2017 17:42 #178033 by 1066Boy
Busta wrote: 1066boy- I was wrong about the rev limiter, I checked this evening. It cuts in at 7,000rpm on the m13a. That's 500rpm past the redline.
Thanks for the update. Mine pulls very well from low revs right through the rev range but stops approximately at 5500rpm.
It never falters at higher revs even around 5000rpm but suddenly at 5500rpm just hits a wall that's why I was asking about
a limiter. Its not really a problem as I very rarely rev it that hard but would like to know why. Any ideas?
  • Riccy
  • Banned
  • Banned
  • J999 MNY Bashing around Carlisle
15 Feb 2017 18:41 #178038 by Riccy
Keithy wrote: Just cruising Riccy.....I don't half miss the turbo....it was quieter in the cab! :D
Have a look at these callipers....early Vitara ones......vented discs are from a Diesel Jimny.....haven't warped yet!
I did the brakes prior to gaining more power........I have discs on the rear too.
Everything fitted straight on and improved the situation.
Old calliper is on the floor in that picture.
that looks good, do you know the hub size for the brake discs you use by any chance? mine uses the 108.something (larger) sized centre bore. If they are for a diesel jimny, then they are hopefully the same for me as they were for you. The calipers look a straightforward swap. did you get the discs from a UK supplier?
By the way, i had a closer look at my swift engine and the throttle body is a drive-by-wire electronic type, so probably no great use to me for any improvement in the jimny. it looks like it is slightly larger bore, and the intake manifold is totally different shape.
15 Feb 2017 19:10 #178040 by Keithy
I think mine are 108mm Riccy.
They are genuine ebay parts for around £30
Order a Liana TB from fleabay.... I paid £28 delivered and was pleased at that!
Remove the Jimny manifold and modify it off the engine...easier to clean that way :D
I'll have to check my wife's Vitara to see if it has the same calipers...it has the same pads Mintex MDB1690.
  • Riccy
  • Banned
  • Banned
15 Feb 2017 19:27 - 15 Feb 2017 19:30 #178042 by Riccy
all the jimny diesel discs i can see on fleebay are the same as the solid/un-vented ones i have? are they an aftermarket demon-tweeks type of thing? the disc internal bore is 108.3mm ive found out.
edit... found out they are vented on later model diesel jims
will have a look for a liana throttle body next...
Last edit: 15 Feb 2017 19:30 by Riccy.
15 Feb 2017 20:55 #178044 by Keithy
No eBay APP ID and/or Cert ID defined in Kunena configurationTry these Riccy
15 Feb 2017 23:16 #178047 by Busta
Try revving it in neutral and see what it does. It seems odd that it would be fine up until 5,500rpm but have nothing after that. If it's reaching the rev limiter you will hear the distinctive 'wa-ba-ba-ba-ba-ba' as the revs cut back.
Time to create page: 0.219 seconds
