Swift 1.6vvt engine into a 2007 vvt jimny project
02 Feb 2017 09:13 #177652 by gilburton
I'm too far away from you in Northants.
It's a 2010 engine with 27000 mls and it cost me £400 It's a bare engine but as you have to swap everything over it doesn't matter.
I started off high and worked my way down ever since :-)
02 Feb 2017 18:55 #177676 by Keithy
gilburton wrote: I'm too far away from you in Northants.
Only 135 ish miles....no worries.
I'm looking for one to rebore .5mm to fit some new pistons to....and conrods :D
  • TomDK
02 Feb 2017 20:02 #177685 by TomDK
Seems like none of you have any thought into how this engine puts out more power and torque than the GV equivalent.
It's done entirely with lots of rpms and no low-end torque, which the GV has much more of.
  • Riccy
  • Banned
  • Banned
  • J999 MNY Bashing around Carlisle
02 Feb 2017 21:58 #177696 by Riccy
Good point well made, i went for the swift engine as thats what was avaliable in good condition, low mileage and decent price. Looking at the different specs the m16a VVT from a SX4 would give the best/optimal output as its setup for high torque at low revs, rather than BHP at high RPMs
This is useful, but does annoyingly jump between metric and imperial a lot:
en.wikipedia.org/wiki/Suzuki_M_engine
Riccy
02 Feb 2017 23:25 #177700 by Keithy
Wifey has the 1.6GV.....bit of a lacklustre engine.....Jimny runs rings round it....even as a 1.3 without a turbo.
M16 while being a little stronger than the M13 isn't as willing to rev and seems a little lacking/uninspiring....that's with the standard 1.3 exhaust manifold which is a little bit crap, might improve with a 4:1.
I think I'll fit a turbo for a little boost.....I'd fit a supercharger but efficiency wins ;-)
03 Feb 2017 00:03 #177703 by Busta
TomDK, it's the same engine, same compression ratio, maybe with sightly different cam profiles but that's it. By the time you put on Jimny manifolds and exhaust the difference is going to be quite small. And some of us like revs anyway :)
Time to create page: 0.268 seconds
