Swift 1.6vvt engine into a 2007 vvt jimny project
07 Feb 2017 00:34 #177810 by Busta
Rhinoman wrote:
Riccy wrote: A thought has occurred regarding braking... or the inadequacy of it in relation to a more powerful engine..
Riccy.
It rather depends on what you intend to do with that power. Braking power is relative to weight and speed, the engine is about the same weight and if you aren't going any faster then then you don't need extra braking. The 1.6 is lower revving so with the same gearing the top speed is usually a little lower - I don't think anyone ever really notices because not many modified Jimnys are driven at high speeds. If you are overgeared then you may get some top speed improvement but its unlikely to be as fast as a stock Jimny.
I can confirm top speed is definitely higher with the 1.6. Although it peaks slighty sooner, the 1.6 is still making more power than the 1.3 at 6,000rpm. Not that the 1.3 will pull 6000rpm in 5th...
07 Feb 2017 17:38 #177829 by Keithy
It's not the braking from top speed that's a problem, it's the braking from speeds previously inaccessible to a Jimny in a short space......much akin to moped riding V getting on a sportsbike where it's all a bit more serious.
07 Feb 2017 18:35 #177831 by Busta
Keithy wrote: It's not the braking from top speed that's a problem, it's the braking from speeds previously inaccessible to a Jimny in a short space......much akin to moped riding V getting on a sportsbike where it's all a bit more serious.
And how quickly you can get back up to speed to get another heat cycle in the brakes.
  • 1066Boy
07 Feb 2017 18:40 #177832 by 1066Boy
Do any of the Jimny models have a rev limiter? Mine revs freely but hits a wall at 5500 rpm.
  • Riccy
  • Banned
  • Banned
  • J999 MNY Bashing around Carlisle
07 Feb 2017 19:39 #177834 by Riccy
Thanks for the reply's,
I will get the swift engine stripped down this weekend (dependant on weather) and have a look at the throttle body and try and post some pics. i think it might be different to the liana inlet system, but will post some pics of it for info.
The braking issue is something ive had issue with for a while. Its mainly manifest when towing, and has got worse since going to 235 tyres, to the point where i wonder if it will stop sometimes. I have also managed to warp discs in the past with it so i think some extra braking will help (and please the insurance company!).
Im not really after top end speed, mearly want to be able to use 5th gear on anything other than a downhill again :-) it would be nice to be able to sit on the motorway at 65-70 without changing gear and revving its nuts off also!
07 Feb 2017 21:04 #177839 by Busta
1066Boy wrote: Do any of the Jimny models have a rev limiter? Mine revs freely but hits a wall at 5500 rpm.
Yes they all do. The limiter cuts in at around 6,600rpm on the m13 and I think higher on the earlier G series engines. Peak power isn't until 6,000rpm so it should sail past 5,500.
Time to create page: 0.291 seconds
