Finished off the rear axle
JimnyIMG_20171028_194347
 So I am finally there on the rear axle. All finished and back on her wheels.
There were a few "cosmetic" items to sort.
First was the air feed for the ARB locker. The old feed had been damaged when the axle parted company from the car in 2011 (see It all goes wrong).
I had previously fitted the new parts for the feed to the diff (see  Fitting the rear wheel bearings)
  7154 Hits
Tags:
Corrected Rear Arms
jimny_IMG_20171017_191842
If you look around the internet, there is a lot of advice and conversation around castor correction for the front radius arms following a spring lift. However there is a lot less discussed about rear axle correction. Clearly "castor correction" does not apply to the rear but there is still an adverse effect due to a spring lift. There are two main effects, the nose of the differential is at the wrong angle which increases the angles the propshaft has to cope with and the spring mounts are not aligned top and bottom resulting in "banana" springs.
  7398 Hits
Tags:
Fitting rear bump stops
JimnyIMG_20171012_183031
The key to a good suspension set up is balance and stability. Over stretching in any direction achieves very little. Ok so the vehicle may seem to have amazing "articulation" but if the tyres are not generating traction (ie pressing on the ground) it does not matter how far they have stretched to touch the ground. Bump stops are a way of protecting the suspension from over compression on one side and the tyres from rubbing inside the wheel arch. Therefore, with a new set of springs and shock I also have gone for bump stop extensions
  8079 Hits
More parts
jimny_IMG_20171006_190403
I am sure I accidentally sold the shock absorbers I had put aside for my refresh of the suspension on BigJimny. Therefore I ordered a new set plus a set of bump stop extenders for the front. Now to get around to putting them on before I sell them again :)
  6363 Hits
Tags:
Installing the diff, shafts and brakes
IMG_20170923_194017
Work has continued over the last couple of days with the re-assembly. First the differential was replaced. I ensured the filler and drain plugs were removed (because this would have been an ideal time to "unstick" them if they had corroded in position) and then cleaned up the housing face.
I then coated the face with sealant, lifted the differential into place and bolted it up.
  6389 Hits
Tags:
