Welcome to BigJimny
BigJimny is YOUR resource for everything to do with Suzuki Jimnys.
If you are new to the site then REGISTER through the LOGIN button
There is a friendly, active FORUM to discuss Jimny related subjects and a web SHOP for all your parts needs.
AS WITH ALL WEBSITES YOUR ATTENTION IS DRAWN TO THE DISCLAIMERS . As this website does not require a login to access content, the accessing of this website and associated resources is deemed acceptance of these DISCLAIMERS. Do NOT progress if you do not accept the DISCLAIMERS
More goodies arrive!
Jimny_IMG_20171109_210355
As we all get older things sag at the front, just ask anyone over 50! My Jimny is heavy and my old springs have worn out. However when compared to the new springs the old ones are actually longer! This is more about turns and wire diameter. The new ones have an extra turn and are made of 13mm wire compared to 11mm so I believe they will hold up rather than just compress and sag like the old ones. I can actually press the old ones by hand!
Still, there is a lot of weight up front so I decided to give the springs a fighting chance.
  8044 Hits
Fitting rear bump stops
JimnyIMG_20171012_183031
The key to a good suspension set up is balance and stability. Over stretching in any direction achieves very little. Ok so the vehicle may seem to have amazing "articulation" but if the tyres are not generating traction (ie pressing on the ground) it does not matter how far they have stretched to touch the ground. Bump stops are a way of protecting the suspension from over compression on one side and the tyres from rubbing inside the wheel arch. Therefore, with a new set of springs and shock I also have gone for bump stop extensions
  8779 Hits
