Stabiliser/Drop Link - MOT Time
​So the MOT time is approaching for "LittleJimny" and we knew that one of the stabiliser links (or drop links) is bent and leaking grease. It is a straight forward process to change these although inevitably occasionally things get stuck. Here is the old link in position, all you have to do is undo the two nuts securing it. ​ As they are swiveling ...
  10989 Hits
ARB air line repair
ARB air line repair
​When the rear axle was ripped off its mount it looks as if the air fitting for the ARB locker was damage. The air fitting consists of pipework fitted through what ARB call a bulkhead fitting. This has pulled out of the diff casing. ​The ARB was not fitted by me and I do not have the instructions. However Google shows that this fitting should be in...
  13171 Hits
What the postman brought....
I used to have a rear disc conversion fitted that I really did not get on with. It never seemed to work properly and needed constant attention in order to get any sort of braking capability. This has been delaying my rebuild as I could not be inspired to re-fit it and go through the trials again. However, I have bitten the bullet and bought a new k...
  9596 Hits
Tags:
ColinK's Jimny
ColinK's Jimny
ColinK has sent in some pictures for display in the gallery, thanks Colin
  8976 Hits
Tags:
Spotted on M3 slipping to A34 North
Spotted - I think its Ali?
  8754 Hits
Tags:
