First proper test run
jimny
We took a little test run out today, just a few green lanes around the area to see how she runs. The lanes are generally in very good condition around here following the local council putting down a loose surface on them a few years back. Therefore they are not taxing but there is enough mud and ruts to bounce the suspension around and to require 4...
  6934 Hits
Tags:
Interior refit
sized_Jimny_IMG_20171210_154635
 So with the MOT passed, we have been driving around this week. Unfortunately, there is a vibration or "push" in the drivechain. I took the rear propshaft off and found the UJs were notchy and very stiff. Taking them apart showed not only rusted out UJs but also a bent yoke. So a new yoke is on order and the car is back in bits in the garage. However this time is it only short lived and I took the opportunity to get on with the interior.
  7456 Hits
Tags:
Into the light!
Jimny_IMG_20171125_140126
​With everything coming together it is time to leave the garage for the first time in 4 years!
  7369 Hits
Tags:
A few more tweaks
regal2250_IMG_20171118_181938
When I started her up for the first time, I noticed a couple of problems. The first was the engine management light (EML) on whilst the second was a stream of water and clouds of steam from the exhaust.
  7473 Hits
Tags:
Wheel bearing
Jimny_IMG_20171121_184231
 Whilst re-building the front axle I noticed that the offside wheel bearing was really rough. It needed changing so off came the hub for a quick change. I originally documented a wheel bearing change HERE so this is more a quick update on changing it again.
  7951 Hits
Tags:
