Todays work
Todays work
A couple of pictures of todays work, full write up to follow.
  12265 Hits
Tags:
Leaking exhaust joint
A while ago I replaced the exhaust on "LittleJimny". Since then I have had great difficulty in getting it to seal. It is a sprung loaded flexible joint so should be a "dry" seal with no sealant or gasket, just a stainless steel mesh ring.
  11658 Hits
Tags:
Snorkel!
Snorkel!
And the snorkel has turned up from www.snorkels.es . This is the cheapest source of snorkels (currently £86 delivered), they respond in English to emails and offer a prompt service.
  11765 Hits
Tags:
BigJimny's LittleJimny build
Well the parts have started arriving! Now that James is old enough to have insurance that permits modifications (Thanks - Adrian Flux) he wants a small and tasteful lift  to perk up the Jimny. Watch this space as the build progresses.
  11286 Hits
Tags:
Fitting new Bits4Vits shock bushes
I have been playing around with fitting the shocks upside down to see if it improved clearance. However, now that I am rebuilding the Jimny, it is time to return it to "normal".
  11916 Hits
Tags:
