BigJimnyMeet 2024
Re:Weird grind\rattle taking off in 1st gear 2019 Jimny
- Shiftingsideways
19 Nov 2019 12:44 #215769
by Shiftingsideways
Replied by Shiftingsideways on topic Weird grind\rattle taking off in 1st gear 2019 Jimny
I have just had mine in for the 2 month check along with fitting a rear camera and mudflaps and I asked them to investigate the noise as I have had it since day 1.
They have just called to say that they have confirmed the noise is in line with the bulletin, Q-A6G-004, and will seek approval from Suzuki GB before ordering the parts for fitment.
Andrew
Andrew
- Bruce
- Visitor
19 Nov 2019 12:49 #215770
by Bruce
Replied by Bruce on topic Weird grind\rattle taking off in 1st gear 2019 Jimny
Q-A6G-004 is what I have been fited from dealer but the noise is still there for some reason.
- Thank you received: 95
19 Nov 2019 18:00 #215780
by Bob1050
Replied by Bob1050 on topic Weird grind\rattle taking off in 1st gear 2019 Jimny
So in a nutshell - exactly what problem is this addressing? Is it sloppy clearances, manufacturing, design or assembly issue? Should I worry? Am I facing a minor irritating noise or am I likely to suffer catastrophic failure at 58.7 mph in 5th gear?
- Turr1can3
- Visitor
19 Nov 2019 21:06 #215784
by Turr1can3
Replied by Turr1can3 on topic Weird grind\rattle taking off in 1st gear 2019 Jimny
I wouldnt be that concerned its something to do with slack in some chain in the xfer box when taking off from first at 2k rpm or more.
I have spoken to another owner.. who is a mechanic and he has the same issue.
He is not overly worried but is aware of it.
Also Bruce .. i wonder if they even did the job..
Its a bit of a worry that the noise is still there.
Anyway early days yet the issue does seem to be wide spread and common.
- Bruce
- Visitor
29 Nov 2019 06:20 #216056
by Bruce
Dealer have tested pretty much everything on my Jimny this week, I'm a little bit concerned about that noise still there even have the transfer case revised kit installed, they changed both transfer case and gear box oil and today I'm taking it to do some offroad, it stay in 4H for around 3hours 4L for around 2hours, drive it back around city straight after that, guess what I found? The noise is unnoticeable, only does it on some really steep hill and the dB is lots smaller than before, so from this point it seems like the more you do offroading the left chance it makes noise......
- Turr1can3
- Visitor
02 Dec 2019 23:50 #216165
by Turr1can3
Yeah
I found if you just put it into 4h then back into 2wd it seems to go away for a while...
Strange..
Strange..
26 Jul 2020 21:41 #225720
by vagepap
Replied by vagepap on topic Weird grind\rattle taking off in 1st gear 2019 Jimny
Hi guys, this is my first post here.
I have the same issue with this noise, as described. Anyone has any more details regarding this bulletin?
I want to know in what extend the engineer has to dismantle the transfer box to install/ replace the bearing. I am afraid that more issues will arise from the fix itself.
Thank you for this forum, it is really useful.
- RobCor
- Visitor
17 Aug 2020 17:24 #226856
by RobCor
Replied by RobCor on topic Weird grind\rattle taking off in 1st gear 2019 Jimny
Yes, I have the same problem. I have a 2020 Jimny. The noise started almost immediately after I just had it for some weeks. The dealer cannot find anything wrong with it and keeps telling me it’s a common thing with Jimny’s and that they all do that. I of course don’t buy that.
My observation is also that while grinding for that half a second I can feel the 4wd lever tremble.
Mine also does it when I pull out with al little bit more gas and always in first gear when I drive up a hill.
So typically it does it when it needs extra push.
Haven’t tried it in 4wd mode yet because I don’t want to use 4wd on tarmac. It’ll ruin it.
If anyone knows if this is a problem that should be fixed I would like to hear more about it. My dealer doesn’t really seem to care.
Besides this noise, I’m in love with the car. I used to drive premium cars (BMW mostly). But this is so much fun to drive. I live on an island and don’t have highways so this is perfect. You barely drive over 80km/h.
- Thank you received: 71
17 Aug 2020 18:23 - 17 Aug 2020 18:23 #226857
by lightning
Replied by lightning on topic Weird grind\rattle taking off in 1st gear 2019 Jimny
l've had a lot of experience with Land Rover Defenders and similar noises can occur on those.
Our 2020 Jimny does do it occasionally. lt sounds to me like the clutch spigot bush or release bearing.
lf, as on the Land Rover, there's a splined joint between the gearbox and transfer box it could be that as well, there's a lot of issues with that part on the later Ford engined Defenders.
As the Jimny comes with a three year warranty l wouldn't worry too much about it, if you've reported it to the dealer it will be in the system. So if the noise gets worse they can't say you didn't tell them about it.
Last edit: 17 Aug 2020 18:23 by lightning.
- Thank you received: 1761
17 Aug 2020 18:37 #226859
Replied by Lambert on topic Weird grind\rattle taking off in 1st gear 2019 Jimny
The Jimny is remote transfer box, there is a service bulletin that is supposed to fix this.
- Jimnyz
- Visitor
17 Aug 2020 23:15 - 17 Aug 2020 23:16 #226872
by Jimnyz
Replied by Jimnyz on topic Weird grind\rattle taking off in 1st gear 2019 Jimny
I had the same problem with my 2011 manual gen3 vvt. Would make the noise daily in first gear on a steep ramp up to my car park at work. Also happened occasionally on the flat while turning from standstill quickly.
I took it back to the dealer while it was under warrantee at around 15,000kms and they came back first that they couldn't hear it, then I took the mechanic for a drive to demonstrate it. They had it for a day and said that they all do that. My friend also has a 2016 gen3 manual that does it.
I drove that 2011 gen3 for 90,000kms before selling it. The noise never got worse and I just lived with it, so I don't think it results in transfer box failure.
My Gen4 is identical in that it has the same noise on the same ramp. I'm convinced that it's just a normal noise for jimnys now.
Last edit: 17 Aug 2020 23:16 by Jimnyz.
- Thank you received: 552
18 Aug 2020 09:15 #226888
by Scimike
Replied by Scimike on topic Weird grind\rattle taking off in 1st gear 2019 Jimny
Have to ask, did they redesign the transfer box for the G4 or is it the G3 box?
If its the same I would have expected it to be just as prevalent in the G3 community. Cant say I have noticed any noise issues on my 56K G3, but then maybe it is common?
Time to create page: 0.148 seconds
