Re:Weird grind\rattle taking off in 1st gear 2019 Jimny
- ITAYKOREN76
10 May 2021 08:08 #234944
by ITAYKOREN76
is it automatic ?
Replied by ITAYKOREN76 on topic Weird grind\rattle taking off in 1st gear 2019 Jimny
is it automatic ?
- Thank you received: 423
10 May 2021 09:31 #234945
Replied by Soeley on topic Weird grind\rattle taking off in 1st gear 2019 Jimny
As far as I know, it's only the Manual that is affected? Someone else might be able to confirm though?
- coellobranco
- Thank you received: 2
10 May 2021 12:37 #234946
by coellobranco
Replied by coellobranco on topic Weird grind\rattle taking off in 1st gear 2019 Jimny
Manual...
watch this video:
watch this video:
- Thank you received: 66
10 May 2021 14:53 #234948
by lightning
Replied by lightning on topic Weird grind\rattle taking off in 1st gear 2019 Jimny
Our 2020 Jimny is a manual and never had any untoward noises from the transmission.
12 May 2021 12:51 #234996
by fordem
Replied by fordem on topic Weird grind\rattle taking off in 1st gear 2019 Jimny
Our 2021 is manual and has the noise.
21 Jul 2021 02:47 #236842
by elliotAs
Replied by elliotAs on topic Weird grind\rattle taking off in 1st gear 2019 Jimny
I have a 2021 model with same noise. Found this below on the German forum. I will mention it on my 1000km check.
"The Service Bulletin Q-AG6-004 of May 22nd, 2019 describes the " Optional spare parts information to reduce the noise from the transfer case when starting up ": Problem Description:When starting off in 1st gear, noises can be heard from the transfer case at approx. 2,000 rpm due to vibrations in the drive chain. Remedial measures:An optional spare parts set has been introduced to reduce noise from the VTG by optimizing friction and damping vibrations in the drive chain. ET information:Drive Chains - Set # 29200-78R00 29951-83050 flange nut (2)29941-77R00 screw retaining spring (2)29946-80051 oil drain plug (1)29945-80051 oil filler plug (1) 09106-06139 Screw, gear lever knob (1)09117-08079 PTO shaft screw (1)"
- Thank you received: 32
21 Jul 2021 22:17 #236858
by crash486
Replied by crash486 on topic Re:Re:Weird grind\rattle taking off in 1st gear 2019 Jimny
Had mine done and now at 20k kms I have the noise in 1st, 2nd and a slightly different noise in 3rd.
Another Aussie is having their TC replaced by Suzuki and yet another Aussie had the input shsft replaced.
Did these sorts of issues occur on previous models?
crash486 JB74W
crash486 JB74W
22 Jul 2021 04:13 #236860
by Jimnyz
Replied by Jimnyz on topic Weird grind\rattle taking off in 1st gear 2019 Jimny
Hi Crash486,
I had it on my 2011 Gen 3 as well as my 2019 Gen 4. I took the Gen 3 in to get it checked by the dealer and they said that they all do that and that it wasn't a problem. I travelled another 90000kms on that one and it never got any worse over that time. I noticed it on the Gen 4, but it was about the same, so I ignored it. In both cases, it only happened occasionally on steep inclines at full throttle in first gear, so maybe not as bad as others.
I figured that if it had a complete failure later on, at least they had a record of it for a future repair under warranty.
Cheers, Mike
Cheers, Mike
22 Jul 2021 07:17 - 22 Jul 2021 11:50 #236863
by lightning
ls this rattle noise a sign of "failure" in the transmission or is it just a noise?
Unless it's a sign of impending failure l am not going to bother getting ours done (although it doesn't yet make the noise)
Unless Suzuki have modified the design, any new parts fitted will likely eventually start making the noise again.
Has anyone had this transfer box drive chain actually fail?
Last edit: 22 Jul 2021 11:50 by lightning.
- coellobranco
22 Jul 2021 07:24 #236864
by coellobranco
Hello, I changed the chain and the noise persists. Now they changed the whole transfer and the noise persists. There seems to be no solution. But there are units that do not have the noise, I do not understand it.
22 Jul 2021 07:37 #236866
by Pspies
Replied by Pspies on topic Weird grind\rattle taking off in 1st gear 2019 Jimny
I have had the transfer chain replaced for this noise under a factory recall. It lasted two months then the noise returned. It is back at the dealers again today for them to evaluate.
My view on all of this is that it doesn't affect my driving of the vehicle on or off road but I want it firmly on record in the event there is a major failure.
Funny enough I watch a branch new Jimny be delivered whilst I was there. As the driver of the new car drove off the lot ...Grrrrt ... there was the sound with 0km on the clock,
22 Jul 2021 11:52 - 22 Jul 2021 11:54 #236875
by lightning
Then it could be just a characteristic of the transmission.
Make it known to your dealer that the noise is there, and then just enjoy your car and forget about it.
You want to try owning a Defender, then you wouldn't worry about a bit of a rattle in first gear from time to time.
Last edit: 22 Jul 2021 11:54 by lightning.
Time to create page: 0.234 seconds
