× A place for more technical discussions. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
33s Rubbing
  • reaper
  • Visitor
  • Visitor
20 Oct 2012 09:07 #50873 by reaper
Replied by reaper on topic 33s Rubbing
Sorry but all this seems a bit extream to me , what lift do you have on and what offset rims ?
When i had the 2" lift and 30" tyres all i had to cut was a little from the plastic arch to get full lock . . . . .your tyres are only 1.5" bigger from hub centre
  • panosd
  • Visitor
  • Visitor
20 Oct 2012 10:21 #50877 by panosd
Replied by panosd on topic 33s Rubbing
No its not that way.
the 30's are 74,3cm tall and 31's are 78.3cm tall. So we talk for 4cm bigger tire but also
20mm wider. The 30's are 245/75/15 and the 31's are 265/75/15.
From numbers to reality there is a big difference. I thought the same when i had to choose
between 31'' and 30'' and i went for 31'' because i said, eeehhh no big deal, is just 4cm.
But when i put them on and saw the trimming needed and some other mods, i understand
it.
  • Smoggy
  • Visitor
  • Visitor
20 Oct 2012 10:43 #50879 by Smoggy
Replied by Smoggy on topic 33s Rubbing
Not sure of the offset but the tyres are 285/75 on 16'' rims with agressive insa turbo tread, its true what Panosd says - in real life they are scary big :ohmy:
  • markyp2000
  • Visitor
  • Visitor
20 Oct 2012 13:10 #50884 by markyp2000
Replied by markyp2000 on topic 33s Rubbing
panosd wrote: No its not that way.
it.
if you have 30" tyres and then fit 31" tyres you only gain 0.5" of ground clearance and get closer to the arches by 0.5"
30's are 74,3cm tall and 31's are 78.3cm tall so thay are only 20mm closer to the rear of the arch and 20mm more ground clearance
  • reaper
  • Visitor
  • Visitor
20 Oct 2012 17:02 #50904 by reaper
it.
The 30" ones were also mt with large lugs and also had 32mm spacers fitted
You are not gaining 3 inch that is the total height you only gain half of that
  • Smoggy
  • Visitor
  • Visitor
20 Oct 2012 18:27 #50916 by Smoggy
All done
  • Paul4x4
  • Visitor
  • Visitor
20 Oct 2012 18:30 #50917 by Paul4x4
Replied by Paul4x4 on topic 33s Rubbing
See, I told you it wouldn't be too hard! :laugh:
Good job, and a lot easier than moving the axle! B)
  • markyp2000
  • Visitor
  • Visitor
20 Oct 2012 18:33 #50920 by markyp2000
job well done better than cutting the chassis mounts off becouse there is more chance of them breaking off
whats that little hole is it some thing you drilled to blow air in to incase of flames or is it already there?
  • Smoggy
  • Visitor
  • Visitor
20 Oct 2012 18:46 #50921 by Smoggy
Thanks guys. The holea are where I injected the cavity wax
  • panosd
  • Visitor
  • Visitor
21 Oct 2012 10:09 #50945 by panosd
Very nice job. Now you must take a careful look at the weldings in order to avoid any holes
left.
  • Smoggy
  • Visitor
  • Visitor
21 Oct 2012 13:46 #50949 by Smoggy
There's always Sikaflex :laugh:
  • Dan13l
  • Visitor
  • Visitor
23 Oct 2012 11:15 #51075 by Dan13l
Replied by Dan13l on topic 33s Rubbing
I no this is a little off topic but on my jimny I am currently running a 3" lift with 30's but thinking of dropping Down to a 2" lift and mix around with my suspension and steering components to get a fairly equal on and off road drive but will the 30's catch, scrub or impede with only a 2" lift it or do I have to drop tyre size as well
Time to create page: 0.121 seconds
Powered by Kunena Forum
