33s Rubbing
- Smoggy
- Visitor
- markyp2000
- Visitor
it can be cut and welded with thicker metal just to restrenthen it
- reaper
- Visitor
Have you not fitted the lift yet ?
- Smoggy
- Visitor
markyp2000 wrote: is that the hinge pillor for the door is it a box section
Yeah it is the door hinge box section but because the main problem is at the bottom of the section I was hoping that cutting it and replating it further back might work.
- Smoggy
- Visitor
reaper wrote: Looks tight in there mate , even with that material removed wont it foul under articulation on the rest ?
All the lifts are in place and thats just taken on the level with no articulation
I have some Grayston spacers which I could fit, this would also widen the track which might help stabilise things a bit - BUT I fear that with those tyres spacers would push the stress on the axles too much, even though they are chromo.
- Smoggy
- Visitor
- reaper
- Visitor
- reaper
- Visitor
Smoggy wrote: Gazwell who sold me the 33s offered me the 1.5'' extended radius arms he has to help with the problem but I fear this may cause more problems by upsetting the castor angle by rotating the setup backwards?
I suspect he also moved the mounting points to compensate for this when he fitted the axles ( were they yota?)
- Smoggy
- Visitor
reaper wrote: Thing with fitting spacers is when locking the steering over the tyre is further out so pushes even more into the door section
Mmm yeah I see what you mean but it would only be at the outer edge of the door pillar then, which I might be able to overcome. The inner arch would be then less likely to catch with the spacers on?
- Paul4x4
- Visitor
But you have more aggressive tires than me, so you'll have more problems. I'm interested to see what's under that corner if you cut it open, because that's what I need to do too when I get some real offroad tires for my Jim.
- Smoggy
- Visitor
- Dorfl
- Visitor
