33s Rubbing
- panosd
- Visitor
1) move the axle brackets of the front radious arms 3cm ONLY forward on the chassis. There is anything
else to do with thus mod. No panar relocation,springs etc.
2) then make a trim of the rear corner that your tires are rubbing at. Then the ''gup'' close it with a new
leaf of alu or iron.
Thats the way people who race at 4x4 comps with jimny's go.
I have also done the 3cm moving and 3 months now have no problem. Also my 31'' not rubbing now.
Take a look to understand better what i say,
Uploaded with ImageShack.us
- Smoggy
- Visitor
- Smoggy
- Visitor
panosd wrote: What you can do
Thanks Panosd, I suppose that Gazwells suggestion of fitting 4cm longer radius arms would serve the same purpose as moving them forward by 3cm, dont you think.
My concerns with this axle moving action is that it may negatively alter the castor of the front axle.
Also I have 33s not 31s like you, what lift is your Jimny please.
- panosd
- Visitor
castor angle. The angle stays the same. You dont turn something. You just get 3cm further. With this
you will also gain better angle and clearence when you go up a hill.
The 3cm that i keep on saying is the limit independed from the ride hight, that you can do
it without any effect on coil spring and shock uper mount, panar bracket etc.
About the 4cm longer radius arms i can't say anything because i don't know their origin-make.
- Smoggy
- Visitor
- panosd
- Visitor
- Smoggy
- Visitor
- panosd
- Visitor
wheels side or just leave it stock.
Take back on the stock one and then do any mod you want.
- Smoggy
- Visitor
- Smoggy
- Visitor
- Paul4x4
- Visitor
- Smoggy
- Visitor
Any comments guys.
