KAP Suzuki Jimny - rebuilt for the road
- Gazguzzler
- Visitor
21 Nov 2016 15:18 #174774
by Gazguzzler
Replied by Gazguzzler on topic KAP Suzuki Jimny - rebuilt for the road
Work has been ongoing, but mainly on the visuals. I looked it little dark and dumpy so a few days with hammerite (in freezing conditions outside) and some ebay stickers have updated it.
On the scissor ramp just finishing off
Tread sticker - I have since altered the front as I didn't like the sharp cut off of the sticker
And finally back on four wheels
Phil
Phil
- Gazguzzler
- Visitor
25 Nov 2016 22:01 #174924
by Gazguzzler
Arghhhh, bloody jeep. Today was a quick finish off of the front suspension and get it ready for the trial on Sunday. I fitted a CB which all went to plan and was quite enjoyable, then decided to change out slipping alternator belt for a new one. Once I stripped out the belts off, I noticed the water pump was completely goosed (funnily enough not leaking) but the play in the shaft was massive, hence the alternator belt slipping. Phoned around at 5pm and managed to get a water pump sourced for tomorrow, but I had the strip down the entire front of the engine including taking the timing belt off
Now I've gotta get it all rebuilt tomorrow night, if I want to go trailing on Sunday.
Phil Birt
Phil Birt
- Visitor
26 Nov 2016 15:27 #174944
Replied by Daniel30 on topic KAP Suzuki Jimny - rebuilt for the road
Life would be boring if everything went to plan you can do it and I'm sure it will be worth it good luck I have my fingers crossed for you
- Gazguzzler
- Visitor
26 Nov 2016 21:17 #174960
by Gazguzzler
Thanks Daniel, I drove 30 miles to pick the promised water pump today from the motor factors, and the pump was completely different, they are getting the right one for Monday, so thats me missing the trial on Sunday
Maybe next time
Phil
Maybe next time
Phil
- Visitor
27 Nov 2016 08:19 #174964
Oh know what a pain
- Gazguzzler
- Visitor
29 Nov 2016 21:25 #175096
by Gazguzzler
I was out today with the NYCD laners for its first big trip, 150 miles and around 20 off road greenlaning. It did very well, I had an issue with a misfire that I sorted out quickly, but then realised after I got home that a front shock had ripped of the axle (usual weak spot). Overall I prefer greenlaning in it then my old defender, the suspension is softer, the clutch lighter, seating position better and less draughts! On the down side it was terribly slow on the hills, but I'm hoping the rocklobster will help with that. I could also do with some less aggressive 215 tyres for road/laning.
- m3
- Visitor
05 Dec 2016 07:49 #175279
by m3
Replied by m3 on topic KAP Suzuki Jimny - rebuilt for the road
Jesus Phil this is some build you have going on here! What days do you work through the week? I'm off a couple days this week, failing that weekends are good would be good to meet up so I can see this!
- Gazguzzler
- Visitor
05 Dec 2016 09:37 #175281
by Gazguzzler
Thanks Ryan, PM sent
- Gazguzzler
- Visitor
06 Dec 2016 18:39 - 06 Dec 2016 18:42 #175339
by Gazguzzler
Today's job - Change out the castor corrected radius arms for Jimnybits ones. The original ones I think were quite old and probably for a +2" lift, which was bowing the front springs, so I updated them to Jimny bits suitable for a +3" lift and new superpro bushes to compliment them.
At the same time the shock absorber lower mount had sheared off on the last green lane day, so I wanted to strengthen these. I started with Jimnybits front shock guards, but as these use the original mounts, I had to scrape off the plastic coating and then weld in some angle iron to pick up on the lower shock mount.
I'm hoping to get it all fitted tomorrow
Phil
Phil
Last edit: 06 Dec 2016 18:42 by Gazguzzler.
- Gazguzzler
- Visitor
06 Dec 2016 18:51 #175347
by Gazguzzler
- Gazguzzler
- Visitor
06 Dec 2016 18:55 #175348
by Gazguzzler
I've tried 5 times to upload the final pic - I give up, you'll have to guess how beautiful the welding was
- Visitor
07 Dec 2016 08:52 #175374
Try using Photobucket might be easier none of my photos upload any more :S
Time to create page: 0.160 seconds
