KAP Suzuki Jimny - rebuilt for the road
- Visitor
11 Jan 2017 17:13 #176575
Replied by Daniel30 on topic KAP Suzuki Jimny - rebuilt for the road
Looking good did you remove the rear bumper to access the wires?
- Gazguzzler
- Visitor
11 Jan 2017 17:28 - 11 Jan 2017 17:29 #176577
by Gazguzzler
Replied by Gazguzzler on topic KAP Suzuki Jimny - rebuilt for the road
Last edit: 11 Jan 2017 17:29 by Gazguzzler.
- Visitor
11 Jan 2017 17:31 #176579
Sorry yeah I meant the jimny :silly: :silly: :woohoo: :woohoo:
Thanks
Thanks
- Thank you received: 663
11 Jan 2017 20:34 #176616
Replied by jackonlyjack on topic KAP Suzuki Jimny - rebuilt for the road
Only problem I had was water ingress
Settling on the wiring and running under the tape
through the grommet and into rear cabin
But sorted that issue now
I would advise you to leave plastic panels out and keep an eye on it
Jack
Jack
- Gazguzzler
- Visitor
11 Jan 2017 20:37 #176617
by Gazguzzler
Good call, I'll make a low point in the wiring loom before it goes through the grommet, that should stop any water
- Gazguzzler
- Visitor
13 Jan 2017 19:31 #176755
by Gazguzzler
Last night and today I have been modifying the rear loom to make it work on the rear upper lights, it was a lot of work, but worth it and it tidies up the back end some what. I now LED number plate, reverse and fog lights as well
In case you are looking to do the same, this saved a lot of time, stolen from another thread on here, not sure who wrote it – sorry
sidelights: red/yellow
indicators: green/red & green/yellow
brake lights: green/white
reverse light: plain red
rear fog light: pale green/black
earth: black
Before
Everything turned on
Towing socket safely in the rear (I also added an audible alert)
Rear Fog / Reverse
Phil
earth: black
Before
Rear Fog / Reverse
Phil
- Gazguzzler
- Visitor
16 Jan 2017 16:48 - 16 Jan 2017 16:50 #176882
by Gazguzzler
Last edit: 16 Jan 2017 16:50 by Gazguzzler.
- Visitor
16 Jan 2017 17:09 #176883
Neat and tidy
Has come along nicely
Well done
Well done
- Gazguzzler
- Visitor
18 Jan 2017 20:48 #176956
by Gazguzzler
Thanks Daniel.
I went laning on Tuesday, another 150 mile day, but was lucky to get home. The drives side front wheel had collapsed and the passenger side wasn't far behind! I limped the last 2 miles and was relived to turn into the driveway! The drivers side had about 1" play at the top of tyre. I have ordered new bearings and the bearing removal tool after reading the very help write up on here.
Whilst I am waiting for the bearing bits, I am taking on another small job - an engine swap! I have managed to source a 1.6 Vitara engine and conversion plate that has been in a Jimny already. So I'm putting this in this week. Tonight I managed to drain the fluids and get some of the ancillaries off, I'll hopefully get a few hours on it tomorrow. No pics yet.
Busy days ahead!
Phil
Busy days ahead!
Phil
- Visitor
19 Jan 2017 00:02 #176963
Bloody hell mate you don't mess about
So lucky you managed to get home :blink:
- Gazguzzler
- Visitor
19 Jan 2017 20:35 #177045
by Gazguzzler
Today, I managed a few more jobs. I got the inlet manifold off which massively opens up access and got the engine wiring loom out of the way. I managed to borrow an engine crane for a week, so that's a relief. Tomorrow hopefully I can get the starter off (access is good now), bottom clutch plate and exhaust and then lift the bugger out! Before I refit the engine I have about a day of changing things, clutch, water pump, new cam belt and a myriad of other jobs. I'll also look in the engine bay and do some rust proofing and maybe change out front brake pipes whilst access is good.
Hopefully get a few pics as well
Phil
Phil
- Gazguzzler
- Visitor
20 Jan 2017 17:19 - 20 Jan 2017 21:01 #177058
by Gazguzzler
The engine is oot!
More work then I first thought and very time consuming working alone - every problem you have to overcome yourself!
Getting lined up ready to lift
Half way out - checking for trapped pipes etc
Then plucked out - I used to 205 tyres so I wouldn't have to lift it so high over the front valance / bull bar
Engine bay - needs a good clean
To do and shopping list - I'll be giving James Priestley a call, as hopefully he will have some of parts
I prefer to do a list, so you can score stuff off as you go along, if not you don't feel like you are making any progress. I am really glad I didn't buy a donor car with an engine in, as it would have been twice the work and then have to get rid of the donor cars shell. At least this way the new engine (bought from James P) was already out, I have just to swap some bits across then throw it back in!
Phil
Phil
Last edit: 20 Jan 2017 21:01 by Gazguzzler.
Time to create page: 0.340 seconds
