Re:Weird grind\rattle taking off in 1st gear 2019 Jimny
  • Dorsetdumpling
15 Jun 2019 21:21 #210006 by Dorsetdumpling
Replied by Dorsetdumpling on topic Weird grind\rattle taking off in 1st gear 2019 Jimny
I’d describe it as a quiet fart.
Seems to come from rear driver’s side on mine.
  • Andy2640
16 Jun 2019 06:22 #210007 by Andy2640
Mines getting progresively more frequent.
Like.... every time i pull away.
The micro grind contines......
16 Jun 2019 08:16 #210011 by Lambert
It is almost certainly the abs pump cycling. Like a 2 second zzzzzzzzZZ noise.
16 Jun 2019 11:33 #210020 by Scimike
Could be the ABS pump as already mentioned.
The ABS pump is a 2 second zzzzzzz noise that occurs once after the engine is started, but only when the vehicle hits a certain speed (let's say 4 mph) in any gear including reverse. After this it will not occur again until the engine is turned off and restarted.
So it's not "every time" the vehicle pulls away, just once per journey, irrespective of load or revs etc.
So people may be referring to different noises including the ABS pump.
Disclaimer - that's how the ABS pump works and sounds on my G3, assume G4 has same bits.
  • mattjimny
17 Jun 2019 00:18 - 17 Jun 2019 00:18 #210040 by mattjimny
Im booking in this week for free 1000km service so im going to get them to check it out, will report back. I doubt its ABS because it does it almost everytime when you pull away in 1st gear. I know it has hill stop assist the brakes come on for like 2 seconds when you let off the brake on a slope
Last edit: 17 Jun 2019 00:18 by mattjimny.
17 Jun 2019 04:32 #210041 by Lambert
It's not the headlight self leveling thing on the back axle trying to cycle the headlights as a consequence of the weight transfer of setting off, possibly?
What I mean is is the noise that of a motor being turned on and off again? More of a buzzing than a clanging or graunching sound?
It just seems that it's being experienced by all gen4 owners and is therefore more likely to be an intended noise rather than a fault.
Time to create page: 0.282 seconds
