Brake problem again!!!!
13 years 6 months ago #69139
by facade
Replied by facade on topic Brake problem again!!!!
Shouldn't be possible for normal humans.
The bearing is a one piece affair with a split centre race, when you tighten it the split closes up and preloads the bearing the correct amount.
Check the vent hole in the fluid reservior cap
- markyp2000
13 years 6 months ago #69141
by markyp2000
Replied by markyp2000 on topic Brake problem again!!!!
If this is the case why have a torque setting if it ok to do it up as FU*KING TIGHT as you can
13 years 6 months ago #69143
by facade
Like most fasteners, if you overnighten, you run the risk of stripping the threads, or overstressing the metal, if you undertighten, they may come undone.
In this particular case, the bearing is not going to be hurt by overtightning the nut, however if the nut is loose, the bearing will open up and there will be play.
The correct torque is 160lbft, 16 stone on a 2ft beaker bar will easily double that. If the spindle stretches over time under the strain then it will come loose.
Best to use a torque wrench as you suggest
- GuardianAngel
13 years 6 months ago #69151
by GuardianAngel
Replied by GuardianAngel on topic Re: Brake problem again!!!!
I will invest in a wrench to be safe.
- GuardianAngel
13 years 6 months ago #69412
by GuardianAngel
I started the process of replacing my king pins tonight (light stopped play) and I noticed that one of the caliper sliders was seized solid. I got it freed up but when moving it back and forth its feels very sticky.
So, could this be the latest cause of my occasional brake pedal dip? The front wheel has no play in it like the drivers side did that caused the problem the first time round (but there is a load of rusty fluid from the hub so I will replace the bearing none the less).
Time to create page: 0.085 seconds
