Brake problem again!!!!
- GuardianAngel
Bled the brakes out, nice firm pedal and guess what...still the same problem :evil: Pedal going down occasionally, but most of the time nice and solid.
It has to be the calipers or rear solenoids, although they are free and can be moved by hand. It's had a new master cylinder, unless I have been unlucky?
Got the rear hose to fit but it will mean hacksawing the brake line as the union is rusted, and building a new front to back brake line and I really dont want to do that.
Any more ideas from the BJ collective?
- markyp2000
Try clamping off all the brake pipes and see of it still sinks then take one off and see if it sinks then clamp it off take another off and so on
- GuardianAngel
markyp2000 wrote: Did you blead out the master cylinder first as in slaken off the pipe pedel down do it up pedel up you may have air traped in it you could try puting a bit of wood no the pedel to the seat over nite that some times work how well are the rear shoes adjusted is there a lip on the drum that need grinding off so you can adjust the shoes up better
It never sinks when stationary and only occasionally when driving. Certain there is no air otherwise the pedal would always sink.
I have checked the rear adjusters several times but I will keep rechecking.
Its a real pain because its off the road and will remain so until sorted.
- SG31061
- GuardianAngel
SG31061 wrote: Hi I had a car that had long brake travel but only after a run does your brakes pulse if you push the pedal softly then it could be a disc or drum that is not running straight pushing back the pads or shoes then when you try the brake pedal it has fill the cylinders or calliper before the brakes work.
I don't think the brake pedal pulses but I will check again. The front discs could do with replacing as they are a bit corroded around the edges so I may just change these.
- GuardianAngel
