Brake problem again!!!!
  • J-Bro
13 years 9 months ago #62773 by J-Bro
Replied by J-Bro on topic Brake problem again!!!!
Since back from the garage I've done about 120 miles. Including inner city and duel carriage way driving and breaks work fine now the pedal is slightly soft then I'd of liked it but with emergency stops it defiantly stops. So at speeds between 20mph and 70mph on a longish journey.
But as I just drove up the by pass to my house (up hill) there was a high pitch whistling sound almost like something rubbing which I've never heard before. Any ideas?
I don't know if its the other bearings or its a sound that's always been there but could never here it due to it being noisy!
But for now I have breaks that are working and hopefully stay that way (touch wood)
  • J-Bro
13 years 9 months ago #62774 by J-Bro
Replied by J-Bro on topic Re: Brake problem again!!!!
It was noisy as hell just didn't put 2 and 2 together
Bearings were next on the list after brakes. Rookie error
  • GuardianAngel
13 years 9 months ago #62883 by GuardianAngel
Replied by GuardianAngel on topic Re: Brake problem again!!!!
facade wrote: If there is no wheel on, there is nothing holding the disc on so it will be loose.
If you have play at the wheel, and it goes away with someone elses foot on the brake, it is wheel bearings.
If the play doesnt go away, then kingpins/track rods.
I tried with the wheel on and it felt solid. But, with the wheel off both the disc and hub move, not just the disk.
  • GuardianAngel
13 years 8 months ago #64697 by GuardianAngel
OK so a bit of an update. The drivers side wheel has a lot of play in it, testing both top/bottom and left/right movement, so its likely my wheel bearing is knackered. The passenger side is rock solid.
I have finished rebuilding pretty much all of the braking system including a lot of the hard lines, flexi-hoses, pads, shoes, disks, rear wheel cylinders, master cylinder etc. I wont be driving it until the bearing is done. I would love to test the brakes to see if I have sorted it but I wont take the chance of driving it until its 100% fixed as best as I can tell.
Its been a long struggle with everything rusted together and lack of time, so can't wait to get the J back on the road. Been a good learning experience though!
  • GuardianAngel
13 years 8 months ago #65316 by GuardianAngel
Right, I had a little test drive outside my house last night. Brakes back together and seem to be working OK, albeit the pedal is a little spongy (either air still in the system or disks/pads/shoes need bedding in).
Guess what? Pedal still occasionally plumets to the floor. So it must be the drivers side bearing causing the problem. I hope......:dry:
  • Tadpole
13 years 8 months ago #65327 by Tadpole
Replied by Tadpole on topic Brake problem again!!!!
Let us know when it sorted, this is like watching paint dry ............ :whistle:
Hope you get this sorted soon GA, it's so frustrating when everything you try gets you nowhere ............... ;)
Time to create page: 0.128 seconds
