Brake problem again!!!!
- markyp2000
Do you no the make
And id buy a blue print (ADL) from some where else
- GuardianAngel
markyp2000 wrote: Well thay buy in bulk from japan so you cant guarantee its a good quality part ie cheap copy
Do you no the make
Its the same make that I replaced, begins with "A" I think but cant remember exactly.
It am having the same problem as I did before changing it which implies it was not the MC. The symptoms I got and still have are not "classic" MC related.
When I have had MC's fail in the past, you could always get the pedal to go to the floor by pressing it very slowly. Stamping ob it would work. It would happen at rest or when driving.
This problem never happens when stationary. I have tried in vain to replicate it many times! It only happens when driving and at any peddle pressure.
Hopefully replacing everything will solve the problem, although I would love to pin point it first.
- Dave cc
Other thing did you use a easy bleed type of device to bleed brake far better than the old pumping the pedal gig that can damage seals in the master cylinder i vac my system out and let it suck the fluid in absolutly no chance of there being air in the system doing it that way
- GuardianAngel
Dave cc wrote: Defo ADL stuff real good but not all factors supply it Proparts down here do ADL stuff not sure if Camberly autofactors do ????
No did it the old skool way. Does it really mess up the seals? Not doubting you but if it did why does everyman and his dog still do it?
- Dave cc
- J-Bro
Hopefully there will be light at the end of the tunnel!
