Brake problem again!!!!
  • GuardianAngel
13 years 6 months ago #69101 by GuardianAngel
Replied by GuardianAngel on topic Re: Brake problem again!!!!
Well, it appears my brake problem has started to come back again. A couple of times in the last day the pedal has dipped. I have jacked up both sides of the J but I can feel no movement at 9/3 and 12/6 o'clock on either wheel. No noises, grinding or otherwise.
However, I suspect it is the passenger side bearing (I replaced the drivers side to fix the last round of problems). I did a test run down my road today and when I drove onto my driveway (which involves a sharp right hand turn), I gave the wheel a sharp turn with a little bit of speed, thinking that putting a lot of lateral load on the left hand front wheel would result in it pulling the pads apart. And indeed it did!
So even when there appears to be no movement, it could be that the bearing is starting to degrade.
  • J-Bro
13 years 6 months ago #69107 by J-Bro
Replied by J-Bro on topic Brake problem again!!!!
At least you know what is it now could be an easy fix from now on!
Mine has been fine ever since the bearing replace
  • GuardianAngel
13 years 6 months ago #69108 by GuardianAngel
J-Bro wrote: At least you know what is it now could be an easy fix from now on!
The bit that worries me is that its not conclusive.
I have come to the conclusion through considered testing. I would have loved to have jacked up the car and have the wheel wobble in my hand.
  • markyp2000
13 years 6 months ago #69116 by markyp2000
Replied by markyp2000 on topic Re: Brake problem again!!!!
Is the wheel bearing torqued up right
  • GuardianAngel
13 years 6 months ago #69117 by GuardianAngel
Replied by GuardianAngel on topic Re: Re: Brake problem again!!!!
markyp2000 wrote: Is the wheel bearing torqued up right
Dont have a torque wrench but used a long breaker bar and stood on it with 16st of weight. But I'm sure its the otherside (for now at least).
  • markyp2000
13 years 6 months ago #69123 by markyp2000
Replied by markyp2000 on topic Re: Re: Brake problem again!!!!
May be over tight and killing the bearing quicker
