Brake problem again!!!!
  • J-Bro
06 Jan 2013 10:15 #57246 by J-Bro
Brake problem again!!!! was created by J-Bro
Okay before Christmas I did a post on my brakes.
Pedal going to floor with little or no brakes
Had brake master cylinder replaced with a used one.
And had all brakes checked and aligned and after that were perfect!
Now the pedal has started going to floor again! It's driving me mad!
Any ideas?
  • Smoggy
06 Jan 2013 10:19 #57247 by Smoggy
Replied by Smoggy on topic Brake problem again!!!!
is the fluid level dropping at all, you may have a leak somewhere.
  • RichiesJimny
06 Jan 2013 11:13 #57251 by RichiesJimny
Replied by RichiesJimny on topic Brake problem again!!!!
Check the fluid level if that's where it should be then that proves you don't have a leak so probably master cylinder again :(
  • jimnybob
06 Jan 2013 13:16 #57262 by jimnybob
Replied by jimnybob on topic Brake problem again!!!!
isnt there something to do with rear brake adjustments or worn out shoes?? ive got the same problem with mine atm :(
  • darthloachie
06 Jan 2013 16:45 #57273 by darthloachie
Replied by darthloachie on topic Brake problem again!!!!
if you go offroad then the rear drums will fill up with mud and you end up with poor brakes and the pedal going to the floor
so check you rear drums for cleanliness and that the shoes move freely etc
  • J-Bro
06 Jan 2013 16:47 #57274 by J-Bro
Replied by J-Bro on topic Brake problem again!!!!
Fluid is fine
At garage before they did the rear alignment
They didn't change shoes.
It is intermetent
Happens more at high speed
Time to create page: 0.413 seconds
