Brake problem again!!!!
  • Dave cc
13 years 10 months ago #57833 by Dave cc
Replied by Dave cc on topic Re: Brake problem again!!!!
Just a long shot as never really had any suzuki brake issues the only other thing in the system is the bias/load valve that sit up under the arse end dont know if anyone has had problems with these ?
Ive had brake pipe issues on a race car years ago where front hoses collapsed would allow fluid in but not back acted like a non return valve
What about mechanical issue ie where the pedal meets the brake servo clevis or what ever suzuki use dont suppose somthing has gone a miss there possibly
13 years 10 months ago #57846 by facade
Replied by facade on topic Re: Brake problem again!!!!
Dave cc wrote: Just a long shot as never really had any suzuki brake issues the only other thing in the system is the bias/load valve that sit up under the arse end dont know if anyone has had problems with these ?
A line from the front and the line to the rear go here, there is a bleed nipple on the unit that bleeds the front circuit.
  • GuardianAngel
13 years 10 months ago #58190 by GuardianAngel
Replied by GuardianAngel on topic Re: Brake problem again!!!!
New BJ hose kit arrived today in blue :)
Will hopefully fit it Saturday and will report back on whether it solves the problem.
  • mcjimny
13 years 10 months ago #58209 by mcjimny
Replied by mcjimny on topic Brake problem again!!!!
With the engine off, does the pedal go hard when pumped?
  • GuardianAngel
13 years 10 months ago #58216 by GuardianAngel
Replied by GuardianAngel on topic Brake problem again!!!!
mcjimny wrote: With the engine off, does the pedal go hard when pumped?
Yes it does, and when switched on, the pedal goes down a bit, so the servo is working OK.
13 years 10 months ago #58240 by facade
Replied by facade on topic Brake problem again!!!!
You might find that the fault lies with the servo, rather than the master cylinder.
If the pedal stays up and solid without vacuum in the servo, but gradually sinks when the engine is running, the fluid level isnt going down, the flexible pipes are ok and it has had a new master cylinder, it is about the only thing left. :unsure:
