Brake problem again!!!!
- rs200boy
13 years 10 months ago #57346
by rs200boy
Replied by rs200boy on topic Re: Brake problem again!!!!
may be a long shot used to be common fault on old fiestas
check front and rear flexi brake pipes and get someone to press brake to pressurise when checking your looking for a bulge under pressure
may not help you but worth a check
- jimnybob
13 years 10 months ago #57349
by jimnybob
also iterested in the results of the new master cylinder please
Replied by jimnybob on topic Brake problem again!!!!
im going to give this a go soondarthloachie wrote: if you go offroad then the rear drums will fill up with mud and you end up with poor brakes and the pedal going to the floor
so check you rear drums for cleanliness and that the shoes move freely etc
- Cautiously reckless rick
13 years 10 months ago #57430
by Cautiously reckless rick
Replied by Cautiously reckless rick on topic Brake problem again!!!!
Make sure the caliper slides are free on the front brakes as this can cause excessive pedal travel worth doing before spending out.
- J-Bro
13 years 10 months ago #57825
by J-Bro
Replied by J-Bro on topic Brake problem again!!!!
Any news with the breaks dude?
- Dave cc
13 years 10 months ago #57827
by Dave cc
Replied by Dave cc on topic Re: Brake problem again!!!!
New units online for less than £70 and seal kits for lss than £20 £250 sounds like a lot for the cylinder and no more than 2 hrs of work to fit and bleed the sysyem
- GuardianAngel
13 years 10 months ago - 13 years 10 months ago #57828
by GuardianAngel
Yes! Fitted a new master cylinder today but alas it still has the occasional pedal dip :dry:
I checked all the calipers front and rear and they are not sticking. There are no fluid leaks (before and after changing the cylinder).
So the next thing to try are the flexible brake hoses. I did notice that one of them (on the front) had the braiding broken off for a small portion of the hose, so I wondered if this would allow the hose to bulge slightly? (as pointed out earlier in this thread but forgot to check :S)
Replied by GuardianAngel on topic Re: Brake problem again!!!!
J-Bro wrote: Any news with the breaks dude?
Last edit: 13 years 10 months ago by GuardianAngel.
Time to create page: 0.099 seconds
