Re:Tyre Pressure for 215/75/R15 ?
- pim123
03 Oct 2022 15:23 #245292
by pim123
Replied by pim123 on topic Re:Tyre Pressure for 215/75/R15 ?
Finally, I have an answer, thank you very much !!! But if I lower my pressure for sand or rocks, it will go crazy ?
- Thank you received: 1999
03 Oct 2022 17:00 #245294
Replied by Lambert on topic Re:Tyre Pressure for 215/75/R15 ?
Yes it gets very cross. It's another case of one system being used across an entire range of vehicles because it's cheaper than designing a separate system for a specific application that has unique requirements. Also you can't turn it off even with an obd tool, you can just reset it but it will go off again soon immediately. Really helpful when the terrain requires 12psi all day.
- pim123
04 Oct 2022 19:24 #245306
by pim123
I see on Youtube vids where they use a switch to kill the fuse temporarely, seems to work
06 Oct 2022 13:04 #245319
by saxj
Replied by saxj on topic Re:Tyre Pressure for 215/75/R15 ?
I'm really glad we don't have TPMS on our local Jimny's, it would drive me absolutely insane. I run 1.5 bar (22 psi) on road and 0.5 bar (7 psi) off-road.
- lookonimages
- Thank you received: 72
09 Oct 2022 18:32 #245350
by lookonimages
Replied by lookonimages on topic Re:Re:Tyre Pressure for 215/75/R15 ?
1.6 to 1.7 bar.
anything more and you really have uncomfortable drive.
24 Oct 2022 02:48 #245550
by NelsonB
Replied by NelsonB on topic Tyre Pressure for 215/75/R15 ?
HR version here came from factory with 215x75 R15! However, It also came with the jampanese pressure recomendation (based in the 205x70 R15 (23front 26 rear). Good for gasoline economy, but very hard drive! Also, the original schocks did not last too much (not economic at the end). I changed suspension to OME and use 22 front -24 rear, most of the time. Soft sand drive, have to reduce to even 8 without problems! BF| ATs.
Time to create page: 0.654 seconds
