Re:isuzu 1.5td 4ec1 engine conversion
  • stimpy
19 Sep 2018 21:39 #196135 by stimpy
Replied by stimpy on topic isuzu 1.5td 4ec1 engine conversion
TomDK wrote:
Venter wrote: How do the torque and power specs compare to the Jimny?
Gearbox ratios?
I'm also thinking of this conversion so will follow your progress. Good luck!
It's a turbo diesel, so a little room for more boost/power. But it's an old heavy lump. A 1.6 G16B/M16a conversion makes more sense and so much easier and cheaper to do. about 20 bhp more than the 1.5 TD, probably only half the weight of and old tired diesel and revs much better. But of course not as fuel efficient.
Haha, I see you're still a ray of sunshine :-)... Looking at the pictures this chap has already started his conversion so has made the plunge already...
Not looked into the specs if I'm honest but don't forget there is normally a shed load more torque from a TD - something a lot folk favour. Also a lot easier to go wading/ swimming with and sort if you do flood it....
Looks like he's doing a grand job. Keep up the good work.
19 Sep 2018 22:02 #196138 by Jefferies
Hi guys, the reason I'm doing the conversion is that I had a jimny previously and couldn't stand the petrol engine's lack of torque and its rubbish fuel economy. I wanted a cheap diesel 4x4 that I can modify and thrash round off road without worrying about it.
Picked this jimny up cheap a few years ago but haven't had a decent place to work on it until recently. I was quite surprised at how few people seem to have done the same conversion, until I realised that the engine won't fit without lifting the body and/suspension. Doesn't bother me because I wanted to do this anyway and it's pretty cheap.
Any input from others doing diesel conversions will be much appreciated , always interested in other people's ideas.
19 Sep 2018 22:59 #196141 by Busta
stimpy wrote: Not looked into the specs if I'm honest but don't forget there is normally a shed load more torque from a TD - something a lot folk favour.
The 1.5td makes 67hp, 97lb/ft. A M16 makes 105hp and 106lb/ft.
I won't knock the fabrication skills and hard work it takes to do this sort of conversion, but a better choice of engine would make the conversion easier and the end result much more rewarding.
  • TomDK
20 Sep 2018 06:46 - 20 Sep 2018 06:48 #196145 by TomDK
Replied by TomDK on topic isuzu 1.5td 4ec1 engine conversion
stimpy wrote:
Gearbox ratios?
I am actually :)
It's nothing to do with bashing what Jefferies is doing. He seems to know what he's doing. I'm just stating the fact, that these old diesels are not exactly performance engines. But you're right, They're excellent for driving in deep water and such.
Last edit: 20 Sep 2018 06:48 by TomDK.
20 Sep 2018 07:52 #196146 by Jefferies
Some of you guys seem to be missing the point.
If your preference is for a relatively low torque petrol engine that you are happy to rev quite a bit then that's fine..... but my preference is for a small enough diesel that will fit the Jimny's tiny engine bay, and one old/simple enough that it actually makes fitting much easier than an ECU controlled more modern diesel. I don't want a "performance engine", and in my opinion there isn't a "better choice" as this conversion is pretty straight forward and it will give me what i want at the end. Comparing two very different engines on max power/torque figures alone is a complete waste of time as it says nothing about the unique power delivery characteristics of each.
20 Sep 2018 15:42 #196157 by Busta
But the engine you chose doesn't fit in the engine bay without other modifications to make room for it. I'm pretty sure a Peugeot XUD does. The Isuzu 1.7td and the VAG 1.9pd have also both been successfully fitted to Jimnys. Those are all readily available, cheap and more powerful yet would require the same amount or less work than your are having to do to make your Jimny slower. Just saying you could have made life easier for yourself with a bit of research.
Time to create page: 0.510 seconds
