Re:isuzu 1.5td 4ec1 engine conversion
31 Oct 2018 23:01 #197221 by Jefferies
Also made a gearbox mount that I think I'm still going to have to modify, im struggling to align the gearbox and transfer box flanges properly. I'm planning on turning up a boss that will bolt to the gearbox output flange that has a hole in the centre that I can put a laser pen in to project the centre axis onto the transfer box flange.
Finished the mod to the steering column
Cleaned up the chassis where the new engine mount brackets will be welded
Shortened the gear linkage and support bracket on the R25 gearbox, was soo easy it was unbelievable
01 Nov 2018 04:59 #197224 by Lambert
Making good progress there.
05 Nov 2018 17:47 #197340 by Jefferies
Made some more good progress on the weekend. I got the new brackets for the engine mounts fully welded onto the chassis, and I made both engine mount arms. Just waiting for some grove green paint to turn up so I can blend them in a bit and stop them rusting quite so fast.
11 Nov 2018 21:15 #197590 by Jefferies
Made an extension for the range lever due to the body lift
16 Nov 2018 19:00 #197704 by Jefferies
Ok so the engine mount brackets on the chassis are painted
And I've ditched the original gearbox mount I made in favour of a new simpler one. The original mount didn't take into account the fact that the engine and gearbox are not coplanar, there is an angular misalignment. Due to the fact that I have mounted the engine vertically the gearbox mount has to take up this angle which is why I made a new one. Just shot a bit of paint on it ready for fitting tomorrow
16 Nov 2018 19:08 #197705 by Jefferies
The gearstick mod has also been designed and some of the parts have been made. The idea is to have a nice long gearstick cranked backwards like a defender. I've designed it with a modified leverage ratio so that it'll essentially give me a short shift
Time to create page: 0.382 seconds
