Swift 1.6vvt engine into a 2007 vvt jimny project
  • Riccy
  • Banned
  • Banned
  • J999 MNY Bashing around Carlisle
13 Jan 2019 21:31 #200682 by Riccy
invincible wrote: stupid question why swap the crank pulley?
Not a stupid question,
Its to keep the belts the standard length and everything spinning at the correct speed (alternator/water pump wouldnt change but PAS and AC would run faster).
Also worth fitting a new one at the swap time as they are a known failure item.
This could even be an advantage having the PAS running faster if fitting larger tyres. Obvs, a different belt would be needed for the PAS/AC to standard (cant remember what now, but easy enough to measure).
  • invincible
14 Jan 2019 17:40 #200731 by invincible
Replied by invincible on topic Swift 1.6vvt engine into a 2007 vvt jimny project
cheers riccy, so the SSS one is a diff size to the jimny one? hence diff speeds,
do you use the 1.6 injectors , i,m guessing so. struggling to find a pre 2010
bare SSS engine , none on fleabay. crank pulley and belt tensioner from martin?
liam.
  • Riccy
  • Banned
  • Banned
14 Jan 2019 17:46 #200732 by Riccy
The SSS and the Liana both have the same pulley. The inside belt is the same as for a Jimny, the outside has a larger pulley than the Jimny, thats the only difference.
Speaking of Liana... you could look for a donor engine there maybe? or even from an SX4. Its even possible to fit a M15 from an ignis sport ;-)
As long as it says M16 and you match VVT or non VVT to what you have already it will work and produce the same power ~ roughly 100bhp.
[Tip - VVT M series engines have a bulge on the crank pulley end for the VVT bit, non VVT doesnt have this bulge]
  • Riccy
  • Banned
  • Banned
14 Jan 2019 17:50 #200733 by Riccy
yes crank pulley, tensioner and oil filter stand are all best prices from Martin (and best service). About the only thing he doesn't regularly sell are oils/fluids.
Yes 1.6 injectors are best to use. You could use denso injectors for a mazda MX5, but it may over-fuel then. Liana inlet manifolds fit i think so worth getting if you find one. Also the earlier (2004) liana throttle body is larger diameter as well as plug-n-play fit ;-)
Or you could mess about with a Rav4 throttle body and make that work for even more air in :laugh:
  • sealine150
22 Oct 2020 06:01 #229378 by sealine150
Replied by sealine150 on topic Swift 1.6vvt engine into a 2007 vvt jimny project
I have done all ready the same setup with the first post. Remap the ECU with M16 fuel plan and still have detonation after 4000rpm or hard push! Any suggested issues?
  • Riccy
  • Banned
  • Banned
22 Oct 2020 17:47 #229406 by Riccy
How have you remapped the ECU then? You are the first to say you have done that...
Which injectors are you using? A rich fuel plan will top out the standard 1.3's pretty quickly or at least run them at a very high duty cycle, but it sounds like you are too lean? I know the 1.8 with throttle bodies & twin injectors I run now in Ulysses puts a LOT more fuel in at higher RPMs, but thats because its aftermarket DTAfast S80 ECU running everything now (albeit in an M18).
