diff guards
  • jonesyba420
  • Visitor
  • Visitor
27 Sep 2013 21:07 #84572 by jonesyba420
Replied by jonesyba420 on topic diff guards
idiotmobil wrote: failing that take you jeep to a big hill roll it over fill it up through the drain plug and roll it back over lol
Im assuming your joking!
  • Wiltec17
  • Visitor
  • Visitor
27 Sep 2013 21:09 #84575 by Wiltec17
Replied by Wiltec17 on topic diff guards
A change in temperature and impact is the best way! Get your hands on an impact gun and a socket to fit, hammer it for a while then big breaker bar, hammer it, breaker bar, it will come loose. Might struggle to jack it high enough to get the breaker bar on it, if a breaker bar isn't long enough, a hollow tube (scaffold pole) helps extend it/add mega leverage.
  • jonesyba420
  • Visitor
  • Visitor
27 Sep 2013 21:11 #84576 by jonesyba420
steffan wrote: There are standard thread some people just do them up real tight I use a harf inch ratchet with a extension bar on it and if that fails I weld a nut on it and use an impact wrench then hay presto an bobs your uncle
this might sound stupid but when you say use a half inch ratchet do I just use the bit the sockets go on?
  • idiotmobil
  • Visitor
  • Visitor
27 Sep 2013 21:12 #84578 by idiotmobil
Replied by idiotmobil on topic diff guards
yes thats what he means
  • steffan
  • Visitor
  • Visitor
27 Sep 2013 21:24 #84580 by steffan
Replied by steffan on topic diff guards
Yes exactly that it sometimes helps if you get someone to hold it in place then give it a good yank (pull)
  • jonesyba420
  • Visitor
  • Visitor
27 Sep 2013 21:30 #84581 by jonesyba420
Ill give it a go in the morning if that fails ill try some heat around the filler plug.
cheers for the speedy help guys.
Time to create page: 0.141 seconds
