Discreet but capable
09 Mar 2018 20:32 #190189
by Jezz
It's been fettled just a tad.
Replied by Jezz on topic Discreet but capable
- Thank you received: 305
09 Mar 2018 22:16 - 09 Mar 2018 22:17 #190195
by sniper
Replied by sniper on topic Discreet but capable
along those lines but perhaps ones that ain't made of platinum......... Louis Vuitton TCA's whatever next, Gucci gearboxes......
sniper
sniper
Last edit: 09 Mar 2018 22:17 by sniper. Reason: grammer
- Thank you received: 2005
10 Mar 2018 05:37 #190210
Replied by Lambert on topic Discreet but capable
That's some pretty serious raid style suspension kit right there. I would suggest that unless you are wanting to upset nemesis or erx drivers it's not entirely necessary to have so much adjustment on a Jimny. Unless you are planning on getting air on sweet lamb on a weekend, if so can I come and crew for you?
10 Mar 2018 10:11 #190223
by sniper
I have had a good look around the car now and put a few K on it, beginning to get a" handle" on it Lambert.
If I choose wisely, I think might be able to have my cake and eat it.
A robust and accurate (adjustable) steering geometry, top end damping, 16" tarmac tyres, 15" forest tyres, 1300cc screamer on throttle bodies.... sounds more like a rally car than a 4x4.
Not really surprising it's where my limited experience lays, my aim I suppose is to find a damper/spring/height combination that will need only damper rates and the change in sidewall flex of the tyre to take it from "tarmac" to "forest".
A compromise on tough off roading but I still think with the ATB diffs front and back, it will be pretty capable.
The ability to do on car adjustments keeps the work within my remit, so keeps long term costs down and allows fine tuning over time.
I do keep watching those diesel brothers programmes and wondering what they could do to a Jimny. If you can sort one those, I'll happily be the idiot doing 60 at the ramp........
sniper
sniper
10 Mar 2018 18:36 #190239
Right well, that's essentially Ermintrude, or will be when I get the 18s funded. Suspension wise for reliability and easy replacement I am using stock components but with sports dampers. Keeps the off road performance to a point where with the 4x4 engaged mobility is not compromised too much on the stock wheels. However on road the sports dampers control over cornering forces is almost beyond physics. Add in the lack of flex of going from a 70 profile to a 45 and an extra 60mm of rubber per axle and serious handling is imminent.
11 Mar 2018 08:58 #190257
Replied by Riccy on topic Discreet but capable
Have a look at Koni heavy track shocks. they make an adjustable damper kit for standard height jimnys..
Time to create page: 0.237 seconds
